Reverse Engineering JPI Engine Monitor Interfaces
email(at)jaredyates.com
PostPosted: Tue Jan 11, 2022 6:37 pm    Post subject: Reverse Engineering JPI Engine Monitor Interfaces Reply with quote
I have purchased a plane that came with an old JPI EDM-700 engine monitor. This is the one with the orange and black display that shows bar graphs for EGT, CHT, etc. It has a data logging capability, but the interface requires their cable, which I don't have:https://www.jpinstruments.com/shop/pc-interface-cable-for-edm-700-edm-800-and-edm-760/
This looks like something that I could make out of things I have laying around the shop, vs spending $40 plus shipping. Does anyone have one sitting around that they could do some continuity testing on? If the little plug only has two conductors, I would guess that there must be two pins on the serial end that they are connected to.
JPI also offers a box that takes the serial from that cable and writes to a USB drive. They charge $200 for that box, and I'd love to see what's in one of those.
Another option is to send the unit into JPI, where they will modify it to have a USB interface for $300.
And of course there is always the option of just pretending like it doesn't record data, but where's the fun in that?
PostPosted: Wed Jan 12, 2022 7:24 am    Post subject: Re: Reverse Engineering JPI Engine Monitor Interfaces Reply with quote
Buy a USB-Serial converter. Research them to get the best chipset.
eBay has converters with a terminal strip for attaching wires.
Connect two wires from the DC plug to the USB-Serial converter.
Nine pin D-Subs are not required.
I have never actually done this. So I don't know if it will work or not.
But if it works, it will only cost you $10 instead of $300.
Joe Gores
cjfortin
PostPosted: Wed Jan 12, 2022 7:53 am    Post subject: Re: Reverse Engineering JPI Engine Monitor Interfaces Reply with quote
If it is a standard RS232 connection, pins 2 & 3 are your transmit and receive signals.
 Filesize:  30.71 KB
 Viewed:  4636 Time(s)
PostPosted: Wed Jan 12, 2022 9:21 am    Post subject: Reverse Engineering JPI Engine Monitor Interfaces Reply with quote
Thanks Joe, I was starting to think the same thing. Seems like a lot of doing then un-doing that could be skipped, when all we're really after is a tx and an rx.
On Wed, Jan 12, 2022 at 10:31 AM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=505670#505670
WIKI -
Peter(at)sportingaero.com
PostPosted: Sun Jan 16, 2022 2:37 am    Post subject: Reverse Engineering JPI Engine Monitor Interfaces Reply with quote
From what I remember from an aeroplane I sold 15 years ago this is a straight RS 232 interface but the serial to USB converter is key, not all work. Don’t forget to switch the Rx & Tx pins on the way to the computer. I believe it is only a 2 wire interface, so I’m guessing the Rx (3) and Gnd (5) pins (at the computer end) are connected?
See also https://mooneyspace.com/topic/35740-jpi-700-cell-phone-serial-data-cable/
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Jared Yates
Sent: 12 January 2022 02:36
Subject: Reverse Engineering JPI Engine Monitor Interfaces
