Powerslide Wheels
erichdtrombley(at)juno.co
PostPosted: Tue Jan 04, 2022 7:38 am    Post subject: Powerslide Wheels Reply with quote
Chris,
After learning what Pete Z. and Ron P. were doing with the Powerslide wheels I ordered one from InlineWarehouse.com to give it a try. I have since ordered a second one.
https://www.inlinewarehouse.com/search-inline.html?sort=no&start=0&count=30&searchtext=Road+warrior+
I wasn’t too keen on the imbalance the valve stem creates and came up with a novel solution. After Pete Z. confirmed he runs his tires close to 10 psi, I realized I could replace the tube with thick wall 8mm silicone tubing. The silicone tube gives just the right amount of squish and retains the tire to the rim, and I don’t have to worry about a flat.
In full disclosure, I have only performed aggressive ground maneuvers to verify the suitability of the silicone tubing. Hope to test fly the new wheel once I remake the wheel fork with slightly different geometry to allow the larger tire/wheel to fit in the wheel well better. It fits fine while testing it on the ground, however, I suspect with wind loads it will have an issue retracting fully into the wing.
Erich
N28ET Classic Mono 914
Top News - Sponsored By Newser
peterz(at)zutrasoft.com
PostPosted: Tue Jan 04, 2022 9:34 am    Post subject: Powerslide Wheels Reply with quote
So  a quick update on my foam-filled outrigger wheel performance.  They are balanced well enough, but without any air pressure I do find the tire does slip on the wheel from landing wheel spin-up - which would make balancing interesting.  I figure if I needed to balance exactly, I would attempt a 'bead-lock' using strategically placed wood-type screws. Haven't gone there yet. Their awesome bearings allow the wheels to spin up in flight (not great), but my simple/light/cheap rubbing fender appears to have eliminated that.
That said, I am extremely happy with their performance, much better wear, light weight (less G-streses on the outrigger and flap), elimination of the 'hammering' of the outrigger mechanisms when using the hard stock wheel on tarmac, and quietness (totally silent/drowned out by the tailwheel noise).
Pete
On Tue, Jan 4, 2022 at 10:47 AM Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)> wrote:
Chris,
Erich
trevord
PostPosted: Tue Jan 04, 2022 10:52 am    Post subject: Powerslide Wheels Reply with quote
Hello Pete,
I copied your “pool noodle” Powerslide filled wheel idea and note your slippage issue.
In other applications, I find that regular clear bathroom silicone sticks anything to anything if it is dry and then not only sticks it well but waterproofs the thing.
It can be removed with a blade if you need to get it off later.
Perhaps that may be a better way to secure the wheel to the rim rather than screws which might create another imbalance – it will also stop water getting in ?
I already used black silicone to plug the valve hole.
Still some way off from flying my Europa but looking out for neat ideas like this.
Trevor
Europa Mono 272
From: <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> on behalf of Pete Zut <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)>
Reply-To: <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Date: Wednesday, 5 January 2022 at 6:25 AM
To: europa-list <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Subject: Re: Powerslide Wheels
Pete
Chris,
Erich
Trevor
Fred Klein
PostPosted: Tue Jan 04, 2022 1:32 pm    Post subject: Powerslide Wheels Reply with quote
I’m curious as to why there seems to be an aversion to inflating these Powerslide wheels…?...
PostPosted: Tue Jan 04, 2022 1:52 pm    Post subject: Powerslide Wheels Reply with quote
Only cuz the tube stem creates a bad imbalance, which requires Ron-sized efforts to correct.
Fred Klein
PostPosted: Tue Jan 04, 2022 2:07 pm    Post subject: Powerslide Wheels Reply with quote
Pete…aha…thanks…and BTW, I’m quite satisfied with my 100 mm skateboard wheels w/ ABEX 9 bearings…not sure of their hardness but quiet and very low rolling resistance...my outrigger rods may be a bit longer than spec as I experience “teeter-toddering” only on taxiways with a high crown…they will not last forever...F.
