Fwd: [europa-committee] What did you do
ward.t(at)xtra.co.nz
PostPosted: Mon Dec 27, 2021 8:55 pm    Post subject: Fwd: [europa-committee] What did you do Reply with quote
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Begin forwarded message:
Date: 28 December 2021 at 5:49:58 PM NZDT
To: europa-committee(at)googlegroups.com
Subject: Re: [europa-committee] What did you do
Jim,Great idea!
In the last month I worked on the speed kit fairings for the outriggers and tailwheel.
They needed protection to withstand the loose stones from a paved tarmac, particularly the tailwheel fairing, which gets substantially damaged due to being in direct line with the main wheel. Using carbon fibre I did two layups, using peel ply, and then a coating of UV West System epoxy. Photo of outrigger show peel ply stage before trimming.
Also installed flashing LED Landing lights on the bottom engine cowl.
See photos. Hi So far, so good.
[img]cid:4D12DFCB-0FCB-43F0-8341-0C803558D8F4-L0-001[/img]
[img]cid:2DB0C458-2160-4999-80F3-7307713C68ED[/img]
[img]cid:2ADBBC9E-88AC-4F24-8385-D2484230CA42[/img]
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
On 28/12/2021, at 9:03 AM, Jim & Heather <butcher43(at)att.net> wrote:
 <![endif]--> <![endif]-->
Hi All,
Starting the thread with replies: http://forums.matronics.com/viewtopic.php?t=16778576
Jim
This email and any files transmitted with it are private and intended solely for the use of the individual or entity to which they are addressed.
If you are not the intended recipient of the e-mail, any files transmitted to you in error, any copying, distribution or other use of the information contained in them is strictly prohibited. The Europa Club’s computer systems may be monitored and communications carried on them recorded, to secure the effective operation of the system and for other lawful purposes.
The Europa Club is a group of individuals drawn together by their interest in the Europa kit aircraft. They include builders, pilots, and those who simply want to know more about the Europa type. The Europa Club is registered as a Type Club of the Light Aircraft Association of the UK.
2021
For more information about the Europa Club,
please visit our web site at http://www.theeuropaclub.org
You received this message because you are subscribed to the Google Groups "europa committee" group.
To unsubscribe from this group and stop receiving emails from it, send an email to europa-committee+unsubscribe(at)googlegroups.com ([email]europa-committee+unsubscribe(at)googlegroups.com[/email]).
To view this discussion on the web, visit https://groups.google.com/d/msgid/europa-committee/000001d7fb5c%24d8a983f0%2489fc8bd0%24%40net
 Filesize:  1.39 MB
 Viewed:  1674 Time(s)
 Filesize:  246.29 KB
 Filesize:  379.15 KB
