What did you do with your Europa this week, 12/20 - 12/26
h&jeuropa
PostPosted: Mon Dec 27, 2021 8:26 am    Post subject: What did you do with your Europa this week, 12/20 - 12/26 Reply with quote
Most days at our house begin with a cup of coffee and then to the computer. I check email, weather, Matronics and Facebook for new posts. I also check new posts on VansAirForce.net. On the weekends the VAF moderator starts a thread entitled “What did you do with your RV this weekend?” I find this thread interesting. Often there are flying stories, but also building stories, photos or motivational posts.
I’d like to do the same here on Matronics and I hope Europa owners around the world will join in. Our flying season in Michigan is about to end with snow on the grass runway, but those of you in the southern US, southern Europe and southern hemisphere should be going great guns. Show us what you are doing!
I’ll start a new thread each week.
Jim Butcher
N241BW XS Mono 914
h&jeuropa
PostPosted: Mon Dec 27, 2021 8:42 am    Post subject: Re: What did you do with your Europa this week, 12/20 - 12/2 Reply with quote
Sunday was a beautiful afternoon in southern Michigan. Temps were above freezing and the sun was out. A short flight along the Lake Michigan shoreline was the result. The snow from three weeks ago is all gone - green Christmas. Finn enjoyed the flight too!
Jim & Heather
 Filesize:  49.76 KB
 Viewed:  6485 Time(s)
 Filesize:  47.1 KB
 Filesize:  65 KB
rlborger(at)mac.com
PostPosted: Mon Dec 27, 2021 10:04 am    Post subject: What did you do with your Europa this week, 12/20 - 12/26 Reply with quote
I sure hope all y’all had a wonderful Christmas!
I’ve spent the last week chasing down a squeak in the aileron rigging. Finally found it this morning. Inside the fuselage, of course. A tufnol bearing seems to be the culprit. Applied a bit of Tri-flow “Superior Lubricant” with PTFE and that seems to have done the trick. No more obnoxious squeak. Now all I have to do is put the airplane back together.
Have a Great Happy and Prosperous New Year!
Blue skies and gentle winds,
Bob Borger
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=505393#505393
http://forums.matronics.com//files/2c5_dec_26_170.jpg
http://forums.matronics.com//files/finn_small_946.jpg
http://forums.matronics.com//files/capture_177.jpg
rparigoris
PostPosted: Mon Dec 27, 2021 9:04 pm    Post subject: Re: What did you do with your Europa this week, 12/20 - 12/2 Reply with quote
Hi Group
Managed to get:
Radiator Duct installed and plumbed:
https://1drv.ms/u/s!Ah1S270Nwg9VgeRkG5WEVIwYZdgWhA
Oil Catch Can installed and plumbed:
https://1drv.ms/u/s!Ah1S270Nwg9Vgd9Zg8VDKuuS_4O8vw
https://1drv.ms/u/s!Ah1S270Nwg9VgeRupcM8vPjXKOb9ZA
Fuel Pressure Regulator plumbed with Aeroquip666-6 hose and fabricated 416SS banjo fittings:
https://1drv.ms/u/s!Ah1S270Nwg9VgeNuuvciL8jMlN7RQw
https://1drv.ms/u/s!Ah1S270Nwg9VgeNjQaNSlLHl4g3BzA
https://1drv.ms/u/s!Ah1S270Nwg9VgeQEcfbZBFCSxUWNxQ
Ron P.
clivesutton
PostPosted: Tue Dec 28, 2021 5:40 am    Post subject: Re: What did you do with your Europa this week, 12/20 - 12/2 Reply with quote
Great posting theme idea Jim.
I'm changing all my rubber components at the moment and just completed taking out and refitting the engine to change the engine frame rubbers, and the fuel hoses etc (Gates Barricade SAEJ30R14 - which is a bit hard to find and expensive, here in the UK).
Took the opportunity whilst i'm working in the tunnel to overhaul my Mono UC as well - disassembly, clean and inspect and checking e.g. linkage bushes before lubing them up and reassembling then resetting the 79mm gap.
Fresh oil hoses and re-purging the oil system, then the coolant system refresh, next.
Clive S
peterz(at)zutrasoft.com
PostPosted: Tue Dec 28, 2021 12:45 pm    Post subject: What did you do with your Europa this week, 12/20 - 12/26 Reply with quote
Busy putting some weekly flight time on my Classic these days (an hour at a time lol).  Have been troubleshooting my new CYA100 AOA which has a habit of going intermittent, and it's hopefully a connector issue not requiring a full rewire and removal of panel etc. (I had reused the builder's original now removed and replaced inop AOA's fuse/wing-wiring).  I love flying in the winter - smooth and great performance.  That said, I've spoiled myself with a heated hangar - which I need to justify (propane is crazy expensive these days!) so the more flight hours the better. So far about 70hrs since getting it back into the air in September after a main frame repair for a bent pivot tube which I have now re-enforced with a truss... along with a laundry list of "make it mine" mods/improvements/fixes.
Just added an unedited (read boring) vid to my Youtube channel with the latest AOA recal. Normally my airport does a great job with clearing the pavement, but this flight was on glare ice surfaces.... makes tailwheeling really smooth and easy peasy Wink but runups not so much lol
Generally I find that if I fly the AOA to the runway I can reliably nail the short full stall landings - luv it. Gives me more confidence than the ASI how much I've got left - leaving me generally too fast.  Now if I could ensure it is reliable Smile
https://youtu.be/19zLV5ddrag
PeteZ
C-GNPZ classic 912S
On Mon, Dec 27, 2021 at 11:35 AM h&amp;jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
--> Europa-List message posted by: "h&amp;jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Jim Butcher
N241BW  XS Mono 914
http://forums.matronics.com/viewtopic.php?p=505392#505392
WIKI -
Fred Klein
PostPosted: Tue Dec 28, 2021 6:38 pm    Post subject: What did you do with your Europa this week, 12/20 - 12/26 Reply with quote
Gents…I received a GoPro10 for Christmas and am looking for accessories.
I’m wondering what kind of attachments are trustworthy for positioning the camera out in the slipstream…what about the sticky pads or suction cups?
Has anybody lost their camera in flight?
