peterz(at)zutrasoft.com Guest
Posted: Sat Dec 25, 2021 11:41 am Post subject: Trim setting question |
Curious:Â My CG is a reasonable 60.86" yet I find that my trim is generally set quite far down in most phases of flight (and never nose up trim).
Is this what other folks are seeing?
Cheers and thx,
PeteZ
C-GNPZ classic 912S
ward.t(at)xtra.co.nz Guest
Posted: Sat Dec 25, 2021 1:12 pm Post subject: Trim setting question |
Hi Pete,I have exactly the same issue but can live with it. Altering it is a real gymnastic exercise with space available and spanners!
Tim
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
| Quote: | On 26/12/2021, at 8:49 AM, Pete Zut <peterz(at)zutrasoft.com> wrote:
Curious: My CG is a reasonable 60.86" yet I find that my trim is generally set quite far down in most phases of flight (and never nose up trim).
Cheers and thx,
PeteZ
C-GNPZ classic 912S
Posted: Sat Dec 25, 2021 1:27 pm Post subject: Trim setting question |
Thx Tim, its good to know im not alone
That said, the tab is neutral, with the stab in line with the fuse moulding, with the indicator also at neutral - so it appears the stab is not lined up with the fuse moulding in flight. I find that odd….
Cheers and Merry Christmas!
PeteZ
| Quote: | On Dec 25, 2021, at 4:21 PM, timward <ward.t(at)xtra.co.nz> wrote:
Tim
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Cheers and thx,
PeteZ
C-GNPZ classic 912S
Posted: Sat Dec 25, 2021 1:48 pm Post subject: Trim setting question |
Yes agree. I only have an issue under a certain loading combination, not common. But you are correct. I only use forward trim, never trimming back behind zero mark.
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
PeteZ
Tim
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Cheers and thx,
PeteZ
C-GNPZ classic 912S
budyerly@msn.com
Posted: Sat Dec 25, 2021 5:36 pm Post subject: Trim setting question |
As Tim said.
Most do not trim in slow flight or stalls to notice the up trim. From takeoff to cruise it is all down trim.
Your CG is a bit farther aft so more down trim is needed in some cases as the incidence of the wing is roughly 2.5 degrees nose down trim is needed as speed increases…
Happy Holidays,
Bud Yerly
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Pete
Sent: Saturday, December 25, 2021 4:27 PM
Subject: Re: Europa-List: Trim setting question
PeteZ
<![if !supportLineBreakNewLine]> <![endif]> | Quote: |
On Dec 25, 2021, at 4:21 PM, timward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
Hi Pete,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
On 26/12/2021, at 8:49 AM, Pete Zut <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
Cheers and thx,
PeteZ
C-GNPZ classic 912S
Pete jeffers
Posted: Mon Dec 27, 2021 2:02 am Post subject: Trim setting question |
Just remember that during build you are allowed a tolerance of round about 1 degree in the tail plane incidence. This is enough to change your trim settings for any particular situation. It will also explain differences between various aeroplanes.Pete J
On Sun, 26 Dec 2021, 13:53 Bud Yerly, <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
Get Outlook for Android
From: Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)>
Sent: Saturday, December 25, 2021, 7:35 PM
Subject: RE: Trim setting question
As Tim said.
Â
Â
Happy Holidays,
Bud Yerly
Â
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> On Behalf Of Pete
Subject: Re: Trim setting question
Â
Â
Â
PeteZ
Hi Pete,
Tim
Tim Ward
12 Waiwetu Street,Â
Fendalton,Â
Christchurch, 8052
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)Â
021 0640221
Â
Â
Cheers and thx,
PeteZ
C-GNPZ classic 912S
h&jeuropa
Posted: Mon Dec 27, 2021 1:04 pm Post subject: Re: Trim setting question |
Interesting this has come up. Our trim has always been near the bottom of the indicator in cruise. I assumed it was because we usually traveled with Jethro, a 50 pound dog in the rear. But after Jethro died, we adopted Finn who is only 20 pounds. The trim still is near the bottom which confirms the operation is correct.
I verified the tailplane trim tab relationship like Pete Z and all is well. The change in CG between 50# and 20# isn't much so it all makes sense.
I haven't verified, but I understand that the trim motor runs further than the indicator, ie you have more down trim available after the indicator is at the bottom.
I use the trim indicator a lot. The "0" or middle position trims the plane for about 65 kts with gear extended. That is the takeoff configuration. During landing I set the trim to one or two lines above the "0" position which results in about 55 -60 kts with gear extended. With the speed set, I control rate of descent with power. It works nicely.
Jim & Heather
Posted: Mon Dec 27, 2021 2:01 pm Post subject: Trim setting question |
Sounds familar, tho with full power and your trim setting, I've got alot of push required on climbout- not good (to me). I take off with the indicator pretty well half way down the down side for a more balanced stick, which results in a forward trimmed stick on engine failure, which i prefer.
Cheers!
PeteZ
| Quote: | On Dec 27, 2021, at 4:11 PM, h&jeuropa <butcher43(at)att.net> wrote:
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=505397#505397
Posted: Mon Dec 27, 2021 3:10 pm Post subject: Trim setting question |
Pete,Agree, I set three units down for take-off.
Tim
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
| Quote: | On 28/12/2021, at 11:08 AM, Pete <peterz(at)zutrasoft.com> wrote:
--> Europa-List message posted by: Pete <peterz(at)zutrasoft.com>
Cheers!
PeteZ
--> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net>
Jim & Heather
_-===================================================bsp; - The Europa-List Email Forum -
= Archive Search & Download, 7-Day Browse, Chat, FAQ,
kingsnjan(at)westnet.com. Guest
Posted: Mon Dec 27, 2021 5:46 pm Post subject: Trim setting question |
Pete,
To answer your question ....... yes.
The thing that intrigues me is not the fact that nose down trim is needed because that is quite normal but the fact that it needs so much nose down trim.
A few years ago I asked the question on this list ........ why is the trim/antiservo tab always displaced so far upwards in cruise (nose down)? I asked this because I observed it in many photos of Europas taken in flight on an angle from which the trim tab could be observed.
It must cause considerable drag I would think!
Cheers
Kingsley in Oz
| Quote: | On 27 Dec 2021, at 3:48 am, Pete Zut <peterz(at)zutrasoft.com> wrote:
Cheers and thx,
PeteZ
C-GNPZ classic 912S
Posted: Mon Dec 27, 2021 5:52 pm Post subject: Trim setting question |
Hello Pete,
I’m at a loss to understand how the tailplane incidence can be set with a fully flying tailplane. Is there an explanation please?
Best regards
Your antipodean cousin
Kingsley
| Quote: | On 27 Dec 2021, at 9:10 pm, Peter Jeffers <pjeffers02(at)gmail.com> wrote:
As Tim said.
Happy Holidays,
Bud Yerly
PeteZ
Hi Pete,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Cheers and thx,
PeteZ
C-GNPZ classic 912S
Posted: Mon Dec 27, 2021 6:01 pm Post subject: Trim setting question |
Indeed I remember that question back in the day!
Now i understand why
Thx!
PeteZ
| Quote: | On Dec 27, 2021, at 8:54 PM, Kingsley Hurst <kingsnjan(at)westnet.com.au> wrote:
Pete,
Cheers
Kingsley in Oz
> Cheers and thx,
> PeteZ
> C-GNPZ classic 912S
rogersheridan(at)mac.com Guest
Posted: Tue Dec 28, 2021 10:03 am Post subject: Trim setting question |
Hi Kingsley,
I am not an aerodynamicist, so this is my uninformed explanation why the trim tab deflection is desirable:
1. Nose down trim is commanding the tailplane to provide lift, this slightly reduces required wing lift along with wing induced drag, so it’s a good thing.
2. If you move the CG forward and tailplane lift required is reduced, the wing induced drag (to maintain level flight) will consequently increase - not desirable.
3. To produce the desired tailplane lift without tab deflection would require an internal trim spring or reduced counterweight and now you’re the test pilot!
Interestingly some Jodel models have all flying tails that are only partially mass balanced, so reducing that lump of steel might work, but I won’t be trying it.
Roger
| Quote: | On 28 Dec 2021, at 01:52, Kingsley Hurst <kingsnjan(at)westnet.com.au (kingsnjan(at)westnet.com.au)> wrote:
Hello Pete,
Best regards
KingsleySent from my iPhone
| Quote: | On 27 Dec 2021, at 9:10 pm, Peter Jeffers <pjeffers02(at)gmail.com (pjeffers02(at)gmail.com)> wrote:Just remember that during build you are allowed a tolerance of round about 1 degree in the tail plane incidence. This is enough to change your trim settings for any particular situation. It will also explain differences between various aeroplanes.Pete J
From: Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> Sent: Saturday, December 25, 2021, 7:35 PM To: europa-list(at)matronics.com (europa-list(at)matronics.com) Subject: RE: Trim setting question
As Tim said.
Happy Holidays,
Bud Yerly
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> On Behalf Of Pete Sent: Saturday, December 25, 2021 4:27 PM To: europa-list(at)matronics.com (europa-list(at)matronics.com) Subject: Re: Trim setting question
PeteZ
Hi Pete,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Cheers and thx,
PeteZ
C-GNPZ classic 912S
Posted: Tue Dec 28, 2021 6:34 pm Post subject: Trim setting question |
Hi Kingsley,
You are correct, I guess it can’t . I was just referring to the fuse moulding (which fairs into the tailplane) appears to me to be at a slightly incorrect angle (for cruise)?
PeteZ
| Quote: | On Dec 27, 2021, at 8:59 PM, Kingsley Hurst <kingsnjan(at)westnet.com.au> wrote:
Hello Pete,
Best regards
Kingsley
As Tim said.
Happy Holidays,
Bud Yerly
PeteZ
Hi Pete,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Cheers and thx,
PeteZ
C-GNPZ classic 912S
n7188u
Posted: Thu Dec 30, 2021 7:36 am Post subject: Re: Trim setting question |
Just to be included in the bunch that confirmed the trim down situation. I always wondered about it but my trim is mostly in two positions: almost full down indication in cruise or right in the center for landing. This airplane is interesting. Is the only one I fly where I turn final and just move the trim to the center in the indicator. That places it at the exact right point for a perfect landing. I don’t bother with continuous adjustments. It’s fun.
Richard Lamprey
Posted: Fri Dec 31, 2021 4:02 am Post subject: Re: Trim setting question |
Pete,
I have my Europa in Kenya, Classic monowheel, my base strip is at 6000’ a.s.l, usually 25-30C, so hot and high, and I have a Rotax 912UL and fixed pitch warp drive. So my conditions are probably different from most. I trim the other way to the way most have discussed here, ie on takeoff I trim nose up – this actually has the bar in the indicator down below the centre, that’s the way I have it configured. On takeoff this trim arrangement pins the tailwheel down, and I keep it that way till 40knots, the minimum required to have tail-up rudder authority. Then, at 40,knots, it requires a gentle but positive push forward to raise the tail. With about 50knots indicated just ease back on the stick, she comes off in ground effect, then forward push to get the speed up. Then with positive climb out at 70 knots trim forward, ie nose down to maintain this and away you go. On landing I have the trim more nose down, so that the flare requires positive back pressure. My own particular way of flying the monowheel, but maybe this helps.
