What Solder !!!
John M Tipton
PostPosted: Tue Dec 14, 2021 6:13 am    Post subject: What Solder !!! Reply with quote
Hi Guys
What is the correct/recommended solder (ratio) to use for us when we do need to solder a couple of wires together
John
trigo(at)mail.telepac.pt
PostPosted: Tue Dec 14, 2021 6:51 am    Post subject: What Solder !!! Reply with quote
Hello John
I am no expert, but I remember being recommended the 60/40.
Cheers
Carlos
Enviado do meu iPhone
No dia 14/12/2021, às 14:24, John M Tipton <johntiptonuk(at)hotmail.com> escreveu:
Hi Guys
John
http://forums.matronics.com/viewtopic.php?p=505250#505250
Ceengland
PostPosted: Tue Dec 14, 2021 7:08 am    Post subject: What Solder !!! Reply with quote
On Tue, Dec 14, 2021 at 8:20 AM John M Tipton <johntiptonuk(at)hotmail.com>
Hi Guys
John
I spent an entire career sticking wires together with Kester 60/40 rosin
core electronics solder, and then heard about 63/37, which makes getting a
good joint, if not a no-brainer, at least a less-brainer. Either works
fine on properly executed joints. If I ever use up what's left of my 60/40,
I'll buy some 63/37.
Quick link to Kester
<https://www.amazon.com/Kester-24-6337-8800-Activated-Solder-No-Clean/dp/B00068IJOU/ref=sr_1_3?crid=15SOO5HVQH6BH&keywords=kester+rosin+core+solder+63%2F37&qid=1639493693&sprefix=kester+rosin+core+solder%2Caps%2C258&sr=8-3>
Charlie
Ceengland
EDIT! I got sloppy doing the search. I didn't pay attention to the part # of that Kester solder. Might be great, but the stuff I've used is Kester 44.
Sorry for the confusion.
Charlie
On Tue, Dec 14, 2021 at 8:58 AM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
On Tue, Dec 14, 2021 at 8:20 AM John M Tipton <johntiptonuk(at)hotmail.com (johntiptonuk(at)hotmail.com)> wrote:
--> AeroElectric-List message posted by: "John M Tipton" <johntiptonuk(at)hotmail.com (johntiptonuk(at)hotmail.com)>
Hi Guys
John
I spent an entire career sticking wires together with Kester 60/40 rosin core electronics solder, and then heard about 63/37, which makes getting a good  joint, if not a no-brainer, at least a less-brainer. Either works fine on properly executed joints. If I ever use up what's left of my 60/40, I'll buy some 63/37.
Quick link to Kester.
If you're a full grown adult doing this as a hobby, you can put what's left of the roll in your will, and your kids can probably do the same in theirs.
Wink
Charlie
Charlie
PostPosted: Tue Dec 14, 2021 8:33 am    Post subject: What Solder !!! Reply with quote
At 08:13 AM 12/14/2021, you wrote:
--> AeroElectric-List message posted by: "John M Tipton" <johntiptonuk(at)hotmail.com>
Hi Guys
John
See attached . . .
Buying solder is a bit problematic . . . it's
increasingly expensive in the common put-ups (1 lb).
A pound of solder will last you a very long time.
Drop me an address and I'll send you some 63/37
in the mail that will probably service your
near term needs.
Alternatively, ebay is a good source for
smaller put-ups. Here's an exemplar offer
https://tinyurl.com/y24xwdmh
out of that stuff?"
09_Terminals.pdf
 Filename:  09_Terminals.pdf
 Filesize:  595.21 KB
 Downloaded:  396 Time(s)
