kitfox IV speedster jury strut questionkitfox IV speedster
kitfox(at)mcn.org
PostPosted: Fri Dec 03, 2021 9:54 am    Post subject: kitfox IV speedster jury strut questionkitfox IV speedster Reply with quote
Good Jack,
My struts are held in by adel clamps too.  Still working well after 29 years.
Kirby
From: owner-kitfox-list-server(at)matronics.com <owner-kitfox-list-server(at)matronics.com> On Behalf Of Jack Bell
Sent: Thursday, December 2, 2021 6:48 PM
Subject: Re: kitfox IV speedster jury strut questionkitfox IV speedster jury strut question
Thanks for the response. I think I have a way to make them fit, have some 1" adel clamps on order to fit to the lift struts. If they were the round jury struts, I could "tweak" them into shape, but these are streamlined, and powder coated to boot, so I have to make the plane fit them, and the supplied clamps, don't. I did find the lift struts were not quite straight, and that helps a bit. There's always something else to work on while parts are on their way!
Jack
Austin, TX
Avid Catalina N92KL (flying)
Osprey 2 N52JB (project on hold)
Kitfox IV speedster (project underway)
Hi Jack      I built my Kitfox 3 with 4 wings in 1993.  The jury strut fittings were a little      off too.  I think if the don't push or pull the wing braces you are ok.      Cheers,            Kirby Cramer      Kitfox 4 NSI Subaru, N45KC       Vans RV7A O-360, N445KC      FAA Experimental Aircraft Repairman      EAA Life Member      I built my Kitfox 3 with 4 wings in 1993.  The jury strut fittings were a little
