kitfox IV speedster jury strut questionkitfox IV speedster
jack(at)comconn.com
PostPosted: Thu Dec 02, 2021 6:48 pm    Post subject: kitfox IV speedster jury strut questionkitfox IV speedster Reply with quote
Thanks for the response.  I think I have a way to make them fit, have some 1" adel clamps on order to fit to the lift struts.  If they were the round jury struts, I could "tweak" them into shape, but these are streamlined, and powder coated to boot, so I have to make the plane fit them, and the supplied clamps, don't.  I did find the lift struts were not quite straight, and that helps a bit.  There's always something else to work on while parts are on their way!
Jack
Austin, TX
Avid Catalina  N92KL  (flying)
Osprey 2  N52JB (project on hold)
Kitfox IV speedster (project underway)
Hi Jack
I built my Kitfox 3 with 4 wings in 1993. The jury strut fittings were a little
off too. I think if the don't push or pull the wing braces you are ok.
Kirby Cramer
Kitfox 4 NSI Subaru, N45KC
Vans RV7A O-360, N445KC
FAA Experimental Aircraft Repairman
EAA Life Member
Fallbrook, CA
YouTube: Cramer's Classic Cycles
