Cold air plenum K&N filter replacement
n7188u
PostPosted: Tue Nov 23, 2021 4:51 pm    Post subject: Cold air plenum K&N filter replacement Reply with quote
Hi forum members,
I am in the process of installing the cold air plenum in my mono (been flying with regular cone filters so far). I got a used plenum which is in very good shape but the filter is not.
I searched for the K&N 33-2564 but it seems this filter is no longer easy to obtain in the US (at least when I tried to search it in the internet).
How to I get one? Is there another K&N filter with similar dimensions that would be easier to get and adapt?
Haven't asked Europa yet.
Best Regards,
Chris
phillik747
PostPosted: Tue Nov 23, 2021 6:36 pm    Post subject: Re: Cold air plenum K&N filter replacement Reply with quote
Hello Chris,
Based on what I could find on the size of the old filter this one came up with a dimension search on K&N. 33-5000
https://www.knfilters.com/33-5000-replacement-air-filter
I used walmarts size to find it.
https://www.walmart.com/ip/K-N-Engine-Air-Filter-High-Performance-Premium-Washable-Replacement-Filter-1989-1994-FORD-Fiesta-Fiesta-III-33-2564/34784068
It might be off a little bit, 2mm or so, if the size from 'wally world' is correct.
Kyle
Kyle
Europa Tri-gear (under construction)
