Anyone with UL94 experience on their M-14P?
yakflyr
PostPosted: Tue Dec 07, 2021 2:30 pm    Post subject: Anyone with UL94 experience on their M-14P? Reply with quote
My airport here in Northern California (KRHV) is going 100% UL94, so I am looking for anyone with experience operating their M-14P on UL94, and any concerns, side effects or modifications needed. Otherwise I may have to sell my Yak 55M since there is no convenient fueling options
Clouddog
PostPosted: Tue Dec 07, 2021 6:03 pm    Post subject: Anyone with UL94 experience on their M-14P? Reply with quote
Leave California!!
On Tue, Dec 7, 2021, 16:36 yakflyr <yak55m(at)gmail.com (yak55m(at)gmail.com)> wrote:
--> Yak-List message posted by: "yakflyr" <yak55m(at)gmail.com (yak55m(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=505193#505193
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
          -Matt Dralle, List Admin.
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
richard.goode(at)russiana
PostPosted: Wed Dec 08, 2021 2:50 am    Post subject: Anyone with UL94 experience on their M-14P? Reply with quote
We have done quite a lot of research into this whole issue of automotive and unleaded fuels with these Russian engines. I attach a paper that we prepared which might give people more information.
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
Use_of_motor_fuels_in_Russian_engines.pdf
Download
 Filename:  Use_of_motor_fuels_in_Russian_engines.pdf
 Filesize:  177.65 KB
 Downloaded:  822 Time(s)
hess737(at)aol.com
PostPosted: Wed Dec 08, 2021 2:27 pm    Post subject: Anyone with UL94 experience on their M-14P? Reply with quote
I've run my M-14P on both high test and low test MOGAS for years with zero issue
Richard Hess
Cell 404-964-4885
yakflyr
PostPosted: Fri Dec 10, 2021 9:48 am    Post subject: Re: Anyone with UL94 experience on their M-14P? Reply with quote
Thanks Richard, that's great to know. Quick follow up question, do you have the regular pistons or high compression pistons?
PostPosted: Fri Dec 10, 2021 10:50 am    Post subject: Anyone with UL94 experience on their M-14P? Reply with quote
The simple fact is that no one has done extensive research on this, but my strong advice, if you have high compression pistons, particularly coupled with a PF supercharger, is to increase the octane rating of the fuel. Either by mixing in 100 LL or with the octane boosters that are available for the automotive racing industry.
yakflyr
PostPosted: Fri Dec 10, 2021 11:17 am    Post subject: Re: Anyone with UL94 experience on their M-14P? Reply with quote
Thanks Richard - I am running into an issue where my home airport and next closest airport is getting rid od 100LL and moving to 94UL, so I am considering my choices. Might have to let go of my 55M after 17 years of ownership Sad
