wdaniell.longport(at)gmai Guest
Posted: Sun Oct 17, 2021 3:56 pm Post subject: Z 16 Charging question |
I have a Rotax 912 with a Z16 and Dynon Skyview
The ammeter sometimes ( defined as once every 25 flights) goes off the chart to 60a. I get the red X over the instrument. Then it comes back and goes down to normal and sits there at whatever loads I have on the system. I have always assumed that this was a Dynon bug.
My Dynon has a shunt installed between the generator and the bus which measures the entire load normally rock steady at 7A or 8A when using the autopilot. I also have an independant hall effect sensor measuring amps on the fat wire to the battery.
Today I noticed on climb out that the hall effect sensor was showing battery charge oscillating from +1.7A to +2.5A - normally it is steady. I switched off the alternator and the hall effect sensor showed steady -7A in agreement with the load shown on my dynon (7A). (I turned around and landed immediately.) Voltage is steady.
I checked the alternator as per https://pointsforpilots.blogspot.com/2012/12/testing-rotax-912914-generator-and.html. All within limits.
So my next steps are to change the regulator, which involves taking out the crowbar because the BandC had one internally, (I had already bought a BandC voltage regulator some time ago) and the battery which is pretty much due for a change.
Any other thoughts?
William Daniell
LONGPORT
+1 786 878 0246
Joined: 28 Mar 2008 Posts: 1963 Location: Riley TWP Michigan
Posted: Mon Oct 18, 2021 3:32 am Post subject: Re: Z 16 Charging question |
There is no way that a faulty regulator can make a Rotax dynamo put out 60 amps.
It is only capable of 20 amps or so. There must be a bad connection somewhere.
_________________ Joe Gores |
Posted: Mon Oct 18, 2021 4:25 am Post subject: Z 16 Charging question |
JoeThanks. Yes ...the first time it happened it caused a bit of worry until i realised i had no smoke in the cockpit...and everything was working normally. And once id calmed down i came to the same conclusion. I have to fault find that.
But what do you think of the fluctuating battery charging level? Is that normal? Or might it be the instrument?
Will
William Daniell
+1 786 878 0246
On Mon, Oct 18, 2021, 07:36 user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=503553#503553
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
WIKI -
Posted: Mon Oct 18, 2021 7:45 am Post subject: Re: Z 16 Charging question |
It is unlikely that the Skyview is at fault. The vast majority of electrical problems are
caused by bad connections. Take every related connection apart and reassemble.
Posted: Mon Oct 18, 2021 8:15 am Post subject: Z 16 Charging question |
....sadly I think you're right.
William Daniell
LONGPORT
+1 786 878 0246
On Mon, Oct 18, 2021 at 11:50 AM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=503558#503558
WIKI -
Posted: Mon Nov 01, 2021 6:30 am Post subject: Z 16 Charging question |
Update:
I installed a bandc AVC 1 voltage regulator. This has integral overvoltage protection and an internal relay simplifying the installation. I changed the voltage pick up location from the shunt to the bus.
Voltage, bus amps and battery charging amps are stable.
Interestingly the headset howl which I suppressed by turning down mic gain has also gone away and I can turn the mic gain up to 50%.
William Daniell
LONGPORT
+1 786 878 0246
On Sun, Oct 17, 2021 at 7:55 PM William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
| Quote: | I have a Rotax 912 with a Z16 and Dynon Skyview
Any other thoughts?
William Daniell
LONGPORT
+1 786 878 0246
