Ceiling headset panel F27 - Wanted
Ordwood
PostPosted: Fri Oct 08, 2021 6:01 am    Post subject: Ceiling headset panel F27 - Wanted Reply with quote
Just wondering if anyone has a spare ceiling headset panel (F27) or the actual pre-moulded ceiling panel (F26) that they’re not using. Thank you.
rparigoris
PostPosted: Sun Oct 10, 2021 11:48 am    Post subject: Re: Ceiling headset panel F27 - Wanted Reply with quote
Hi Orwood
I have a ceiling panel I will never use. Located in states. That said I didn't much like the molded Europa part. It's made with polyester resin. I want my ceiling panel removable and it ends up the polyester part warps and is not dimension-ally stable. I figured that out after fitting it. I ended up using a piece of thin G-11. Very stable, did a layup on the aft side and it ends up lighter than the Europa part.:
Look at page 2:
http://www.europaowners.org/gallery2/v/Begin-06-2003/Cockpit+above+door+sills/album222/
Ron P.
