582, B box, electric starter & Ivoprop for sale
Richard Pike
PostPosted: Sun Jun 20, 2021 5:54 pm    Post subject: 582, B box, electric starter & Ivoprop for sale Reply with quote
About ready to put it on ebay, but posting it here first, and cheaper; here is all the leftover stuff from converting the MKIII to the 72" prop
The Aquilla trike the engine came off. Includes an unmounted fairing, and what you will need to haul it on a small utility trailer. No kite.
Run-out 582, appears to be a good core, late model w/large crank, apparently around 320 hours. One minor scuff on one cylinder wall.
Electric starter, had a crack at the mounts 5 years ago, professionally repaired, no problems since
68" two blade Ivoprop, good condition.
Out of date BRS
$1800 for everything, you pick up at Indian Springs airport, 3TN0
 Filesize:  369.5 KB
 Viewed:  3805 Time(s)
 Filesize:  340.91 KB
 Filesize:  235.33 KB
 Filesize:  213.73 KB
 Filesize:  528.06 KB
 Filesize:  204.02 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
