Charlie Mike
Posted: Wed Jun 23, 2021 7:03 pm Post subject: Aileron balance tubes and weights? |
My slingshot has the aileron balance tubes in place. I have the weights that go inside to neutralize control. There are no holes in either to secure the weights. The drawings show a bolt thru set up. …. Are you using these? And if so, how are the weights secured in the tubes?
_________________ Kolb Slingshot 582, C gearbox. |
Richard Pike
![](images/avatars/57903806352d56370bc2be.jpg)
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Thu Jun 24, 2021 4:33 pm Post subject: Re: Aileron balance tubes and weights? |
Disconnect your aileron pushrods from the ailerons, and slide the weights back and forth in the tubes until the ailerons balance level. Drill a hole through the tube/weights and stick an AN3 bolt through it. Do it vertical so it won't foul the wingtip.
Like a lot of other things in aviation, it turns out to be pretty simple, but back when I built my MKIII, I didn't know either.
And w/o the balance weights, my ailerons would start to flutter at 88 mph. Good mod.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Charlie Mike
Posted: Fri Jun 25, 2021 12:58 pm Post subject: Re: Aileron balance tubes and weights? |
Thanks Richard…
