Cup holders?
digidocs
PostPosted: Sun May 30, 2021 5:01 am    Post subject: Cup holders? Reply with quote
Anybody have a slick cup holder setup for the front seat?
I'm currently rocking the stock tunnel with no console.
David
rleffler
PostPosted: Sun May 30, 2021 5:26 am    Post subject: Cup holders? Reply with quote
Aerosportproducts.com
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of David Carr <junk(at)dcarr.org>
Sent: Sunday, May 30, 2021 9:00:00 AM
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Subject: Cup holders?
David
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
dmasys2(at)gmail.com
PostPosted: Sun May 30, 2021 7:34 am    Post subject: Cup holders? Reply with quote
Not slick but cheap and effective, have used one of these for the past 13 years, velcroed to the center tunnel far forward (just behind velcroed halon fire extinguisher):https://www.amazon.com/Hopkins-SMT-Go-Gear-Cupholder/dp/B000FGIBYQ
Pulse oximeter fits in the little compartment between the cup holders.
-Dan Masys
On Sun, May 30, 2021 at 6:31 AM Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> on behalf of David Carr <junk(at)dcarr.org (junk(at)dcarr.org)>
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
David
rjones560xl@gmail.com
PostPosted: Sun May 30, 2021 7:51 am    Post subject: Cup holders? Reply with quote
I put in a South Florida Sport Aviation armrest with cup holders. It is very light a screws down with the existing tunnel cover screws. It starts aft of the fuel selector. I don’t have a throttle quadrant. My engine controls are hung under a Stein Air instrument panel in a custom made panel. If you have the whole throttle quadrant from SFSA or Aerosports you probably have to stick with their products to make them work together.
https://sfsportaviation.com/index.php?route=product/product&path=62_81_83&product_id=59
[img]cid:384A9F4C-404A-4324-9B66-92C0337845F9[/img]
Robert Jones
Get Outlook for iOS
David
 Filesize:  1.84 MB
 Viewed:  8780 Time(s)
Robert J Jones
702-521-1840
Bob Turner
PostPosted: Sun May 30, 2021 3:03 pm    Post subject: Re: Cup holders? Reply with quote
I built a center arm rest out of some spare foam, covered it with left over cloth from the interior side walls. Mounted a plastic fold-up cup holder from Amazon (3 for $10 if I recall) to the forward side of the arm rest. Right size for a 12 oz soda can; works okay. Truth is, I rarely use it. If I'm taking fluids along for me, I usually look for a plastic bottle with wide-mouth, screw on cap, just in case I have to put the fluids back, if you catch my drift...
Bob Turner
RV-10 QB
