changing Nose tires, CJ6
draftsjust417(at)gmail.co
PostPosted: Tue Jun 01, 2021 10:14 am    Post subject: changing Nose tires, CJ6 Reply with quote
Ok my fellow CJ maintainers, another question...
Sooner than later, I'll need to replace my stock Chinese nose tire. (I'd like to keep it stock Chinese; inner tube seems okay & holding pressure.)
How best to separate and re-join the wheel halves?
I've serviced the NLG bearings, but never split the actual wheel.
Advice, tips, do's and don'ts?
Expanded pic from parts catalog attached.
Thanks, any info very
much appreciated---
Justin
N280NC
 Filesize:  2.5 MB
 Viewed:  3024 Time(s)
jonboede(at)hotmail.com
PostPosted: Tue Jun 01, 2021 10:51 am    Post subject: changing Nose tires, CJ6 Reply with quote
You will find this to be incredibly easy when you get to it, no worries.
One point on pushing the axle out... either a deep socket of just the right size or a wooden dowl that's turned to the right size will be of much help. Don't use a metal hammer on anything.
Jon
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Justin Drafts <draftsjust417(at)gmail.com>
Sent: Tuesday, June 1, 2021 1:14 PM
To: yak-list(at)matronics.com <yak-list(at)matronics.com>
Subject: Re: changing Nose tires, CJ6
much appreciated---
Justin
N280NC
PostPosted: Tue Jun 01, 2021 11:38 am    Post subject: changing Nose tires, CJ6 Reply with quote
Awesome, thanks! Yup yup, found a deep socket that worked very well when I last greased the nose bearings...
Thanks for input!
Justin
On Tue, Jun 1, 2021, 11:55 AM Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
Jon
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> on behalf of Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)>
To: yak-list(at)matronics.com (yak-list(at)matronics.com) <yak-list(at)matronics.com (yak-list(at)matronics.com)>
much appreciated---
Justin
N280NC
PostPosted: Tue Jun 01, 2021 4:00 pm    Post subject: changing Nose tires, CJ6 Reply with quote
New nose tire install done, was surprisingly easy, thanks for the inputs all!Justin
N280NC
On Tue, Jun 1, 2021, 12:38 PM Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Thanks for input!
Justin
Jon
much appreciated---
Justin
N280NC
 Filesize:  2.65 MB
 Viewed:  3021 Time(s)
