mike(at)vision499.com Guest
Posted: Tue May 25, 2021 8:01 pm Post subject: Constant Speed Propeller |
Hello
I have a LOM constant speed propeller that is leaking a small amount of
oil from the base of the boss that the prop blade is mounted in where it
rotates on the prop hub.
Is the leak significant and should it be repaired?
If it needs to be repaired is it something I can do myself?
Mike
| | - The Matronics Lom-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
89.78 KB |
11402 Time(s) |
Untitled_attachment_00114.txt |
25 Bytes |
722 Time(s) |
