Noseleg assembly NG01
flyingphil2
PostPosted: Mon May 24, 2021 6:14 am    Post subject: Noseleg assembly NG01 Reply with quote
A bit of a random question.
I have a noseleg assembly - NG01 (see the rear part of this in the attached image). Should I be able to disassemble this by sliding the sub assembly off the main tube or is this designed to be a friction fit and unmoveable without great effort?
I'm concerned that there is corrosion between the outer noseleg tube and inner sleeves of the rear sub assembly, which is why I can't separate them to check, but maybe it's not designed to come apart?
Phil
 Filesize:  863.25 KB
 Viewed:  2790 Time(s)
peter.rees01(at)tiscali.c
PostPosted: Mon May 24, 2021 6:56 am    Post subject: Noseleg assembly NG01 Reply with quote
If you’re talking about the leg and the articulating frame, they should be a good fit with loctite to hold them together (from recent experience of replacing both on HI).
Phil
http://forums.matronics.com/viewtopic.php?p=502039#502039
http://forums.matronics.com//files/img_0863_620.jpg
