A Lumley
Joined: 12 May 2021 Posts: 10 Location: Ontario, Canada
Posted: Thu May 13, 2021 11:10 am Post subject: Contactor Questions |
Good afternoon,
I'm working on a schematic for my RV-10 based on the Z-101 architecture and have come up with a couple questions about contactors...
First, about the starter contactor. The Z-101 shows a single conductor connecting the contactor to the starter with a jumper at the starter. I found another discussion from 2015 with an alternative arrangement (attached) for permanent magnet starters. I'm planning to use a B&C starter. Should I be using the extra wire & diode?
Second, I'm adding an external power outlet per Z-31A. I've made sense of most of this drawing but I'm unsure why there is no diode shown across the coil in the Z-31A diagram? The B&C continuous contactor includes an external diode already. Should it be removed?
Thanks for taking the time to read my perhaps basic questions!
68.33 KB |
4181 Time(s) |
46.57 KB |
4181 Time(s) |
Posted: Thu May 13, 2021 3:57 pm Post subject: Re: Contactor Questions |
Z-31A does not require a diode because the over-voltage module provides arc suppression.
No, do not remove the B&C installed diode. It does not hurt anything.
_________________ Joe Gores |
Posted: Thu May 13, 2021 7:31 pm Post subject: Contactor Questions |
At 02:10 PM 5/13/2021, you wrote:
| Quote: | --> AeroElectric-List message posted by: "A Lumley" <andrew.lumley(at)sympatico.ca>
Good afternoon,
First, about the starter contactor. The Z-101 shows a single conductor connecting the contactor to the starter with a jumper at the starter. I found another discussion from 2015 with an alternative arrangement (attached) for permanent magnet starters. I'm planning to use a B&C starter. Should I be using the extra wire & diode? |
By 'extra wire' are you talking about the jumper from
contactor "I" terminal to the starter's "S"
terminal? Yes, wire as shown and including
the diode is a good thing. The starter contactor
from B*C will include a built in diode on its
coil.
| Quote: | | Second, I'm adding an external power outlet per Z-31A. I've made sense of most of this drawing but I'm unsure why there is no diode shown across the coil in the Z-31A diagram? The B&C continuous contactor includes an external diode already. Should it be removed? |
Wouldn't hurt but not necessary assuming you
can get a B*C crowbar ov module. Are those
available? I though those were out of production.
| Quote: | | Thanks for taking the time to read my perhaps basic questions! |
That's what this organization is here for
my friend . . . folks that already know everything
don't need us!
out of that stuff?"
A Lumley
Posted: Thu May 13, 2021 7:42 pm Post subject: Re: Contactor Questions |
Thanks to you both for the quick feedback. I'll include the jumper from the contactor "I" terminal to the starter with the extra diode.
You are correct that B&C no longer sells the crowbar module so I was going to build my own from your crowbar schematics.
Thanks again, I'm sure I'll have lots more questions...
