Voltage regulator connection
Paul M 383
PostPosted: Sun May 09, 2021 11:53 am    Post subject: Voltage regulator connection Reply with quote
Has anybody seen this voltage regulator connection issue? One of the yellow generator connectors has clearly got hot and is too close to its slot in the plug.
It's definitely melted, not vibration or mechanical abrasion and looks like it's simply too close to the edge of its slot in the plug.
How to avoid re-occurrence?
(Apologies for the first image - auto focus Rolling Eyes )
Many thanks in advance,
Paul M
Europa Mono with 912 ULS
G-PLPM
 Filesize:  251.77 KB
 Viewed:  15107 Time(s)
 Filesize:  166.74 KB
 Filesize:  136.45 KB
kilocharlie767(at)gmail.c
PostPosted: Sun May 09, 2021 12:30 pm    Post subject: Voltage regulator connection Reply with quote
Like this?
Sent from KC
(Apologies for the first image - auto focus [Rolling Eyes] )
Paul M
G-PLPM
http://forums.matronics.com/viewtopic.php?p=501803#501803
http://forums.matronics.com//files/20210509_125502_138.jpg
http://forums.matronics.com//files/20210509_125515_179.jpg
http://forums.matronics.com//files/20210509_125602_142.jpg
 Filesize:  281.37 KB
 Viewed:  15103 Time(s)
williamtsullivan(at)att.n
PostPosted: Sun May 09, 2021 1:51 pm    Post subject: Voltage regulator connection Reply with quote
My first thought is a loose connection, leading to arcing.
Bill Sullivan
Tarboro, NC
On Sunday, May 9, 2021, 03:55:32 PM EDT, Paul M 383 <europaul383(at)hotmail.com> wrote:
--> RotaxEngines-List message posted by: "Paul M 383" <europaul383(at)hotmail.com (europaul383(at)hotmail.com)>
Paul M
G-PLPM
http:/p;   -Matt Dralle, List Admin.
Paul M 383
Yes! Although mine wasn't as bad as that...
What was the cause and, more importantly, what was the fix to prevent recurrence?
Best,
Paul M
-------- Original message --------
Date: 09/05/2021 21:34 (GMT+00:00)
Subject: Re: RotaxEngines-List: Voltage regulator connection
[img]cid:365cfa72-9ddc-4329-a606-9b881b34edf5(at)eurprd03.prod.outlook.com[/img]
Like this?
Sent from KC
> --> RotaxEngines-List message posted by: "Paul M 383" <europaul383(at)hotmail.com>
> Paul M
> G-PLPM
 Filesize:  281.37 KB
 Viewed:  15098 Time(s)
PostPosted: Sun May 09, 2021 4:12 pm    Post subject: Voltage regulator connection Reply with quote
Welp, the cause wasn’t a loose connection. This was on my RV-12, installed IAW original instructions.  It occurred with less than a 100 hours TT. Van’s came up with a different installation and different regulator. I opted for it.   So far, so good.
Ken
Sent from KC
On May 9, 2021, at 4:54 PM, Paul Mansfield <europaul383(at)hotmail.com> wrote:
Best,
Paul M
Subject: Re: Voltage regulator connection
<image0.jpeg>
Like this?
Sent from KC
> Paul M
> G-PLPM
John Kirkgaard
PostPosted: Sun May 09, 2021 10:57 pm    Post subject: Re: Voltage regulator connection Reply with quote
This happens when the connection is not 100% tight. Bad connection creates heat.
John
Paul M 383
PostPosted: Mon May 10, 2021 9:36 am    Post subject: Voltage regulator connection Reply with quote
Glad you got it resolved Ken,
What was the different installation (and what different regulator, out of interest)?
Best,
Paul M
Date: 10/05/2021 01:15 (GMT+00:00)
Ken
Sent from KC
Best,
Paul M
<image0.jpeg>
Like this?
Sent from KC
> Paul M
> G-PLPM
rparigoris
PostPosted: Mon May 10, 2021 11:17 am    Post subject: Re: Voltage regulator connection Reply with quote
Hi Paul Looks like a high resistance connection, it turned to a mini toaster. Rotax supplied pretty poor fast-on connectors for some time. My 914 had the poor ones. Vans went to the Silent regulator for a while, Silent said it would not warranty their regulator unless you had phosphor bronze fast-ons. I went with a B&C AVC1 regulator, nice piece. They include phosphor bronze fast-ons or you can buy them separately in their $5 field kit: https://bandc.com/product/avc1-advanced-voltage-controller-homebuilt/#installation-kit Ron P.
PostPosted: Mon May 10, 2021 12:11 pm    Post subject: Voltage regulator connection Reply with quote
Paul,Van’s moved the regulator from under the instrument panel on the co-pilot’s side to the left forward side of the firewall (engine side). They changed the regulator to a Silent and since have changed it again to a B&C. If and when my Silent fails, I will go to a B&C.
KEN
Sent from KC
On May 10, 2021, at 12:40 PM, Paul Mansfield <europaul383(at)hotmail.com> wrote:
Best,
Paul M
Ken
Sent from KC
Best,
Paul M
<image0.jpeg>
Like this?
Sent from KC
> Paul M
> G-PLPM
