RPM Sensor setting E-Mag Series 200-6XL with AFS 4500 EM
Mike Whisky
PostPosted: Sun May 02, 2021 1:36 pm    Post subject: RPM Sensor setting E-Mag Series 200-6XL with AFS 4500 EM Reply with quote
Hi,
installed my new E-MAG P200-6XL and had to rewire the AFS RPM sensor ( RPM signal wired to the Mag) I also did change the pin from the 5V signal Pin 32 to the 12V signal pin 33. In the software setting the AFS 44500 EM asked for pulses per 2 revolutions, E-MAg says it provides 3 pulses per revolution. I set it therefore to 6.
Problem is now that I get 0 RPM reading and the familiar RPM circle gauge changed in into a red multi-spike star see attached picture. Anyone has an idea what gone wrong?
On the setting page I can see the pule count working.
Kind Regards
Michael
Strange RPM Symbol and 0 RPM reading
 Filesize:  155.83 KB
 Viewed:  5374 Time(s)
RV-10 builder (flying)
#511
Mike Whisky
PostPosted: Mon May 03, 2021 6:46 am    Post subject: Re: RPM Sensor setting E-Mag Series 200-6XL with AFS 4500 EM Reply with quote
Problem solved. It looks that the data has not been correctly saved. I changed the max RPM value and saved it. RPM gauge is back like it was before and the reading is correct as well.
Mike
#511
