Posted: Wed Apr 28, 2021 5:24 am Post subject: How to seal Tygon tube to barb fittings |
At 08:12 AM 4/28/2021, you wrote:
| Quote: | I make a tourniquet using two wraps of lacing cord. Really easy and seems to work fine.
Steve Stearns
O235 Longeze
Boulder / Longmont CO
Here's a string tie technique that produces a
very secure installation:
https://tinyurl.com/ydms6p4a
Used this yesterday to refurbish the CO2 discharge
line on my DIY 'sodastream'. The old one I cut off
had been on there 5+ years and was still tight.
out of that stuff?"
rparigoris
Posted: Thu Apr 29, 2021 7:27 pm Post subject: Re: How to seal Tygon tube to barb fittings |
Hi Group
Thanks for replies. I ended up using on suspect barbs either double .025" safety wire or a constrictor single or double knot using lacing cord, then a drop of thin CA. Ron P.
rparigoris
Posted: Thu Apr 29, 2021 7:37 pm Post subject: Re: How to seal Tygon tube to barb fittings |
Hi Group
BTW working with A65 Tygon tubing, the 5/32" ID and 9/32" OD is a tad too large for a few of my barb fittings but I mentioned how I solved that issue (either double wrap of .025" safety wire or single or double over constrictor knot using lacing cord and a drop of thin CA). It's also a tad too small for others. I brought over a ceramic coffee mug with a 300 watt immersion heater and heated water to 170F. 10 seconds of Tygon dipped in makes it nice a pliable with near zero chance of hurting the tubing. You can kinda sorta use a heat gun, but you need to be really careful. Overheat just a little too much and you damage tube permanently. Ron P
