ken(at)kbeene.com Guest
Posted: Sun Apr 18, 2021 4:35 pm Post subject: KN72 connection |
I am installing a kx125 to KN72 and KN75 and Dynon HS34 to Dynon D100. Both the KX125 and the KN72 will output CDI +/- and TO/From. The HS34 supports both CDI +/- and LOC +/-. Neither the KX125 or the KN72 has an output called LOC +/-. I think the CDI +/- maybe the LOC +/- when ILS Energize is activated. Should I use the output from the KX125 or the KN72 for the HS34. Should I connect the CDI + to the LOC + and the CDI- to the LOC- also. The KN72 is mostly to support the OBS resolvers I think.
Ken
RV4, J3 Cub, Acrosport I, Cherokee. Restoring a Cessna 172.
Posted: Mon Apr 19, 2021 10:52 am Post subject: KN72 connection |
At 07:33 PM 4/18/2021, you wrote:
| Quote: | I am installing a kx125 to KN72 and KN75 and Dynon HS34 to Dynon D100. Both the KX125 and the KN72 will output CDI +/- and TO/From. The HS34 supports both CDI +/- and LOC +/-. Neither the KX125 or the KN72 has an output called LOC +/-. I think the CDI +/- maybe the LOC +/- when ILS Energize is activated. Should I use the output from the KX125 or the KN72 for the HS34. Should I connect the CDI + to the LOC + and the CDI- to the LOC- also. The KN72 is mostly to support the OBS resolvers I think.
That's a bit out of my wheelhouse . . . check with
Stein at Steinair:
"SteinB" <stein(at)steinair.com>
out of that stuff?"
