		NebraskaYak
				 Posted: Sun Apr 11, 2021 6:32 pm    Post subject: Rotax 582 high EGT's |
				Hi All,
 Just got my 582 powered plane out after winter hibernation. Everything was fine when we parked it and now both EGT's are trending high, right up to 1200 on takeoff and over 900 at 3000rpm. Never saw them so high before. Rebuilt fuel pump, checked carb floats, new fuel lines and filter, fresh gas and swapped egg gauge with no changes. Any ideas what would cause both to be so high all of a sudden?
 Thanks for the help!
 Andrew
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sun Apr 11, 2021 6:47 pm    Post subject: Rotax 582 high EGT's |
				Is it fresh gas?
        Bill Sullivan
        On Sunday, April 11, 2021, 10:34:47 PM EDT, NebraskaYak <andrew.malousek(at)comcast.net> wrote:
                 --> RotaxEngines-List message posted by: "NebraskaYak" <andrew.malousek(at)comcast.net (andrew.malousek(at)comcast.net)>
 Hi All,
 Andrew
 http://forums.matronics.com/viewtopic.php?p=501356#501356
 _/Navigator?RotaxEngines-List" target="_blank">http://www.matronics.com/Na=               - MATRONICS WEB FORUMS=   --> /wiki.matronics.com" target="_blank">http://wiki.matronics.com
 http://www.mat====
		NebraskaYak
				 Posted: Sun Apr 11, 2021 6:55 pm    Post subject: Re: Rotax 582 high EGT's |
				yep, drained and filled with fresh premix
				 Posted: Mon Apr 12, 2021 6:13 am    Post subject: Rotax 582 high EGT's |
				My only other thought is to check your connections.  Oxidation would cause a change in electrical resistance.  Pull the plugs, and clean the contact surfaces.
                                                      Bill Sullivan
        On Sunday, April 11, 2021, 10:56:22 PM EDT, NebraskaYak <andrew.malousek(at)comcast.net> wrote:
 http://forums.matronics.com/viewtopic.php?p=501358#501358
 http://www.matronics.com/Navigator?RotaxEngines-;          - MATRONICS WEB FORUMS -
 http://forums.matronbsp;         - NEW MATRONICS LIST WIKI -
 _-========================sp;          - List Contribution Web Site -
 http://www.matronics.com/contributi======================
		skyguynca
				 Posted: Mon Apr 12, 2021 7:03 am    Post subject: Rotax 582 high EGT's |
				Seals are leaking, crankshaft seals probably. It will suck in air past the
 seals and cause you to run lean.
 They dry out and start leaking after years of being installed. Doesn't
 matter how many hours. Long sits during winters without being preserved
 properly can be the culprit too.
 David
		ppsel03
				 Posted: Tue Apr 13, 2021 4:51 am    Post subject: Re: Rotax 582 high EGT's |
				 	  | NebraskaYak wrote: | 	 		  Hi All,
 Andrew |
 Assuming you've 2 plugs per cylinder, One of the mags is not sparking.   Unburned fuel is burning in the exhaust.
  _________________ EuropaXS 914UL Turbo |
		Guy Buchanan
				 Posted: Wed Apr 14, 2021 3:17 pm    Post subject: Rotax 582 high EGT's |
				Check for an air leak at the boots. Unfortunately your crank seals may
 have dried and allow air to pass. There's a way to check but I don't
 remember it. I think there's a spec for crankcase vacuum or manifold
 vacuum that might tell you something about leakage.
 On 4/11/2021 7:32 PM, NebraskaYak wrote:
  Hi All,
  Andrew
Deceased K-IV 1200
A glider pilot too. |
