Splicing shielded pair
mburbidg(at)gmail.com
PostPosted: Sat Apr 03, 2021 5:52 am    Post subject: Splicing shielded pair Reply with quote
Hi,
Is there a video or instructions somewhere that describe how to splice shielded pair wire?
Michael-
art(at)zemon.name
PostPosted: Sat Apr 03, 2021 8:21 pm    Post subject: Splicing shielded pair Reply with quote
Michael,
I soldered ground wires to the shields. You could probably adapt that technique. See the three photos at the bottom of my blog post Wiring Harness Installed.
    -- Art Z.
On Sat, Apr 3, 2021 at 9:24 AM Michael Burbidge <mburbidg(at)gmail.com (mburbidg(at)gmail.com)> wrote:
Hi,
Michael-
https://CheerfulCurmudgeon.com/Friendship is like a stone. A stone has no value, but when you rub two stones together properly, sparks of fire emerge.
Rabbi Mordechai of Lechovitz
alec(at)alecmyers.com
PostPosted: Sun Apr 04, 2021 3:03 am    Post subject: Splicing shielded pair Reply with quote
You strip back the shields, slide a length of shield braid over cable, and a length of heat shrink. Splice and insulate the conductors individually on a staggered basis, then slide the loose shield braid over the join and solder around both ends. Finally insulate over the top with sleeving.
On Apr 4, 2021, at 12:22 AM, Art Zemon <art(at)zemon.name> wrote:
Michael,
-- Art Z.
Hi,
Michael-
PostPosted: Sun Apr 04, 2021 3:17 am    Post subject: Splicing shielded pair Reply with quote
Or this:
http://www.aeroelectric.com/articles/Shielded_Wire_Splicing/S_Wire_Splice.html
Michael,
-- Art Z.
Hi,
Michael-
