Posted: Sat Mar 13, 2021 1:05 am Post subject: Cable securing from instrument board and aft - IDEAS??? |
Ron, I like the idea of supporting the sill and anything suggested by Nev has status second only to utterances by Ivan. Like many mono pilots I have taken to getting in and out of my plane from in front of the wing with a phase of sitting on the sill part of the process. over the years the gel coat below the sill developed longitudinal cracks which might well have been avoided by an interior section of fibreglass forming a conduit.
Having said that I am not clear that you actually need conduits in most parts of the plane. If you are going to line the cockpit with any light material then wires can simply be stuck neatly in the line under the sill or wherever and the lining material simply lightly glued over it. Building light should be high in your priorities.
Regards, David Joyce, GXSDJ (914/WoodcompCS/mono/full panel +autopilot, initial ready for service weight 833lbs)
On 2021-03-13 00:13, rparigoris wrote: | Quote: | --> Europa-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>Hi Alan I glassed a piece of Balsa to not only enclose a conduit, but add support to sill. Nev gave me this hint. http://www.europaowners.org/main.php?g2_itemId=86882 RonRead this topic online here:http://forums.matronics.com/viewtopic.php?p=500950#5bsp;--> http://www.matronics.com/Navigator=  f="http://forums.matronics.com" target="_blank" rel="noopener noreferf="http://wiki.matronics.com" target="_blank" rel="noopener noreferre========================http://www.matronics=====================
