Antenna Grounding
Eric Page
PostPosted: Mon Feb 08, 2021 5:03 pm    Post subject: Antenna Grounding Reply with quote
I think I know the answer to this question, but I'd like confirmation: does an antenna ground plane have to be electrically bonded to the airframe?
The aircraft is a Kitfox, which has a steel tube fuselage. In an effort to keep the outside of the plane as clean as possible, I'm trying to put as many antennas as I can inside the fabric envelope. For example, the comm antenna...
https://www.aircraftspruce.com/catalog/avpages/antennasystems.php
...is mounted inside the vertical stab. Other Kitfox builders have reported good performance with this antenna in the tail, despite a couple of steel tubes in the vicinity.
Since the transponder and ADS-B antennas...
https://www.aircraftspruce.com/catalog/avpages/ted_transponder.php
--and--
https://www.aircraftspruce.com/catalog/avpages/monopole11-13561.php
...are so short, they'll easily fit inside the wings. I can fabricate a ~3" diameter ground plane from aluminum sheet for each of them, but there's no way to electrically ground those plates to the airframe if they're suspended inside the wings. Is that a problem, or is a good bond from coax shield to ground plane all that's needed? Thanks.
PostPosted: Mon Feb 08, 2021 7:51 pm    Post subject: Re: Antenna Grounding Reply with quote
No, the ground plane does not have to be grounded to the airframe.
Com antennas should be vertically polarized. The ANTENNA VHF-5 will work in a wing,
but not very well. It might work well vertically in the tail.
How about this antenna for $45?
https://www.aircraftspruce.com/catalog/avpages/stainlessantenna.php
You could make your own antenna.
http://www.aeroelectric.com/articles/Antennas/DIY_Comm_Ant/DIY_Comm.html
But for $45, it will be easier to buy one.
Mount it vertically inside of the fuselage. It can either point up or down.
Make a ground plane out of 4 wires going out in 4 directions.
Keep the first half of the antenna away from airframe tubes.
Use a SWR meter to check how well the antenna works.
What engine are you using in your Kitfox?
Joe Gores
PostPosted: Mon Feb 08, 2021 7:56 pm    Post subject: Re: Antenna Grounding Reply with quote
Did you mean 3 inch radius for the transponder antenna? 3 inch diameter is too small.
The radius should be at least as long as the antenna.
Joe Gores
PostPosted: Tue Feb 09, 2021 6:19 am    Post subject: Homemade Antenna Reply with quote
Bob N describes how to make a com antenna in his book on page 13-10.
http://www.aeroelectric.com/Books/Connection/13_Antenna.pdf
Joe Gores
Eric Page
PostPosted: Tue Feb 09, 2021 10:00 am    Post subject: Re: Antenna Grounding Reply with quote
OK, that's what I thought.
Com antennas should be vertically polarized. The ANTENNA VHF-5 will work in a wing, but not very well. It might work well vertically in the tail.
Indeed. I installed the VHF-5 vertically, inside the tail.
Whoops! Yes, I meant radius.
Thanks, Joe.
PostPosted: Wed Feb 10, 2021 3:41 pm    Post subject: Antenna Grounding Reply with quote
no ground to aircraft needed for the UHF antennas.
However, their RADIUS is equal to the seated height
of the antenna so closer to 6" diameter for ADSB
and 5.75" for the xponder antenna. Orient them
so that the antennas extend down from the ground
plane.
It's hard to argue with customer satisfaction
for any particular antenna configuration . . .
but I'd really like to see a sweep of the
antenna mounted in the vertical fin. At the least,
proximity of metal to the antenna might well
call for physical 'shortening' of the antenna.
out of that stuff?"
Eric Page
PostPosted: Thu Feb 11, 2021 9:04 am    Post subject: Re: Antenna Grounding Reply with quote
nuckolls.bob(at)aeroelect wrote:
...RADIUS is equal to the seated height of the
antenna so closer to 6" diameter for ADSB and
Yeah, the 3" diameter was a brain fart on my part. I meant radius.
...I'd really like to see a sweep of the
I have a poor-man's VNA, so I'll see what I can do. I ordered some RG-400 last night, so it'll be a week or two before I can mock up a test. If I can make the VNA show something that looks sensible, I'll post it here.
According to the manufacturer's data, this antenna cannot be shortened.
