mike(at)vision499.com Guest
Posted: Mon Feb 01, 2021 6:21 pm Post subject: EFIS Erratic Temp Readings |
Hello
I have an EFIS that has erratic temperature readings when the engine is running.
Manufacturer has suggested that EMI interference introduced by the ignition system may be the culprit and has suggested shielding the leads with tin plated copper braid that is grounded. I am unable to locate copper braid near me and will have to wait for a delivery from Aircraft Spruce. Will wrapping the leads with aluminum foil replicate the shielding effect for test purposes.
The EGT leads (clamp on probe type) are already covered with a braided covering, which I presume is Stainless Steel for physical protection, will this act as an EMI shield and if yes how do I ground it?
Copper Braid is sold in 1/8, 1/4, and 3/8 nominal flat width, any guesses as to what size will accommodate k-type thermocouple leads.
Kellym
Posted: Mon Feb 01, 2021 6:35 pm Post subject: EFIS Erratic Temp Readings |
While I suppose it is possible that EMI could cause erratic readings, I
tend to think the rate of erratic reads would be too fast for you to
detect. A very high percentage of erratic readings are cause by
inadequate connectors between the probe and the aircraft harness. Spade
connectors or ring connectors are common. They can be made to work
correctly for a period of time, but typically will degrade to inadequate
conductivity. The only connector I know that has worked 100% of the time
for me is the Electronics Internation OLC-2 connector(OlC-1 worked too,
but was harder to use.). It can be obtained in multiples of 5 from EI
for the bargain price of $1 ea.
https://iflyei.com/product/olc-2/
On 2/1/2021 7:19 PM, mike(at)vision499.com wrote:
| Quote: | Hello
running.
KCHD |
Dave Saylor
Posted: Mon Feb 01, 2021 7:11 pm Post subject: EFIS Erratic Temp Readings |
I can't tell you how effective foil would be but maybe the group can help troubleshoot. Can you describe how it changes? Quickly, with large displacements, on/off, gradually, etc? Is it around the range you would expect? Is it a single cylinder measurement or similar behavior at different cylinders?
--Dave
On Mon, Feb 1, 2021 at 6:27 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Hello
_________________ --Dave
KWVI |
mikepienaar09(at)gmail.co Guest
Posted: Mon Feb 01, 2021 9:52 pm Post subject: EFIS Erratic Temp Readings |
If I only have sensor connected temperature reading is different for each “scan” and varies by up to 150 degrees between max and min.
If I connect more sensors readings become more and more erratic. Even if no sensors are connected “ghost” readings appear for cylinders not connected with the same reading for EGT and CHT. Ghost readings vary from between -50 to 800 degrees.
Hope that helps
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of David Saylor
Sent: February 1, 2021 7:10 PM
To: aeroelectric-list <aeroelectric-list(at)matronics.com>
Subject: Re: EFIS Erratic Temp Readings
--Dave
Hello
Kellym
Posted: Tue Feb 02, 2021 6:08 am Post subject: EFIS Erratic Temp Readings |
Understand that both EGT and CHT are thermocouples that measure small
changes in resistance. If you have nothing connected the resistance can
float. If you have less than solid, airtight soldered, crimped or screw
connection, the resistance will float. I'd still put my money on
connections that are not airtight. I fought the same issue thinking I
had bad probes until I switched from spade connectors to the OLC-2
connectors. Temps are now rock solid. Same for fuel flow sensor. In fact
on fuel flow the connection improved enough I had to lower the K factor
between .5-1%. You can get all the connectors needed for $30 for a 6
cylinder or $20 for a 4 cylinder. AFAIK EI changed all of their
instruments to the OLC-2 connectors instead of spade connectors.
I seriously doubt you will see much improvement with shielding the whole
system.
On 2/1/2021 10:51 PM, mikepienaar09(at)gmail.com wrote:
| Quote: | If I only have sensor connected temperature reading is different for
Hope that helps
*From:*owner-aeroelectric-list-server(at)matronics.com
<owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *David Saylor
*Sent:* February 1, 2021 7:10 PM
*To:* aeroelectric-list <aeroelectric-list(at)matronics.com>
*Subject:* Re: EFIS Erratic Temp Readings
--Dave
<mailto:mike(at)vision499.com>> wrote:
Hello
is running.
ground it?
KCHD |
Posted: Tue Feb 02, 2021 8:38 am Post subject: EFIS Erratic Temp Readings |
At 08:07 AM 2/2/2021, you wrote:
| Quote: | --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com>
Understand that both EGT and CHT are thermocouples that measure small changes in resistance. |
Actually very TINY changes in VOLTAGE generated
by the Seebeck effect . . . small temperature
dependent voltages generated at the junction
of dissimilar metals.
| Quote: | I had bad probes until I switched from spade connectors to the OLC-2 connectors.
Temps are now rock solid. |
Joint quality in thermocouple feeds
are important given the very tiny
voltages involved.
| Quote: | | I seriously doubt you will see much improvement with shielding the whole system. |
Agreed, It is exceedingly rare that adding shields
fixes any problem in an instrumentation
system.
out of that stuff?"
Posted: Tue Feb 02, 2021 9:41 am Post subject: EFIS Erratic Temp Readings |
At 11:51 PM 2/1/2021, you wrote:
| Quote: | | If I only have sensor connected temperature reading is different for each scan and varies by up to 150 degrees between max and min. |
Whoops . . . missed this out the gate. If the readings
are THAT erratic you may have something else going on.
Is this a new condition or did it crop up after a period
of normal ops?
Are the readings believable when the engine is not
running? Does turning the alternator on/off make
a difference?
Are your thermocouples on the engine electrically
isolated . . . i.e. not grounded to the engine?
Does the EFIS installation manual speak to the need
for 'isolated' thermocouples?
The gross excursions of reading sound more like
a ground loop issue as opposed to connector quality.
out of that stuff?"
Posted: Tue Feb 02, 2021 1:51 pm Post subject: EFIS Erratic Temp Readings |
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Robert L. Nuckolls, III
Sent: February 2, 2021 8:48 AM
Subject: RE: EFIS Erratic Temp Readings
of normal ops?
Aircraft has never flown, only noticed this while testing engine.
a difference?
Readings seem stable and accurate when engine not running, will test this again.
Will run to-morrow and then disconnect alternator
Not sure what this means
I have K Type bayonet EGT sensors that clamp onto Exhaust and 1 yellow and 1 red wire that connects directly to MGL RDAC unit
CHT sensors are under plug with same wire setup
Cannot find a reference for “isolated “ thermocouples
I have taken a ground from the EFIS directly to the engine block. The engine mounting bolt is grounded to battery and to the starter motor
I have also tried it with the RDAC ground attached next to the EGT sensor but this made no difference
None of the leads are joined, they go directly from the sensor to the MGL RDAC unit
Mike
out of that stuff?"
Ceengland
Posted: Tue Feb 02, 2021 2:05 pm Post subject: EFIS Erratic Temp Readings |
snipped
Cannot find a reference for isolated thermocouples
snipped
Mike
| Ask MGL which style (grounded or ungrounded) they require for their RDAC.
Ground issues might not be limited to the sensors; poor/inconsistent ground reference could be related to the RDAC, or the EFIS, or ???.
Charlie
_________________ Charlie |
Posted: Tue Feb 02, 2021 7:57 pm Post subject: EFIS Erratic Temp Readings |
At 02:12 PM 2/2/2021, you wrote:
| Quote: | --> AeroElectric-List message posted by: Dick Tasker <dick(at)thetaskerfamily.com>
Actually, the voltage is not generated at the junction. It is effectively generated along the whole length of a conductor due to the temperature difference between the two ends. In fact, the only reason we get any output to measure is that the two wires of a thermocouple are chosen to have different Seebeck coefficients. |
Actually no. There are TWO junctions. One is
attached to the temperature of interest, the
second resides at some REFERENCE temperature.
WAaayyy back when, multiple thermocouples scattered
about a test airplane at Cessna were paired with
'reference' thermocouples immersed in an distilled
water ice bath (0 degrees C).
The real temperature of interest is deduced by
comparing the test thermocouple with the reference
thermocouple. Views -A- and -B- in this excerpt
from the 'Connection.
http://www.aeroelectric.com/articles/Thermocouple%20Junctions.pdf
The reference junction doesn't have to be an ice bath,
it can be part of the indicating instrument wherein
'reference' is cabin environment temperature . . . there
will be compensating thermistors in the instrument to
improve accuracy over a range of cabin environments.
Non-electronic thermocouple instruments of old actually
measured that difference voltage with meter movements that read
full scale with tens of millivolts applied. In these
cases, there was considerable current flowing in the
thermocouple leads compared to electronic displays.
Hence, thermocouple wire lengths and wire gages were
critical to accurate measurement.
Electronic displays don't need to draw current from
the thermocouples hence, wire length and gage
don't matter . . . there are no voltage drops in the
lead wires. JOINTS in those runs are critical
in that they need to occur in pairs so that potentially
parasitic junctions cancel each other out. See chapter
10 in the 'Connection.
out of that stuff?"
Posted: Wed Feb 03, 2021 8:39 am Post subject: EFIS Erratic Temp Readings |
| Quote: | Is this a new condition or did it crop up after a period
of normal ops?
Aircraft has never flown, only noticed this while testing engine. |
Good data point.
| Quote: | Are the readings believable when the engine is not
a difference?
Will run to-morrow and then disconnect alternator |
Also, while exploring effects of alternator
operation, you might dis-mount temperature
sensors from engine and let them hang free
not touching engine.
| Quote: | Are your thermocouples on the engine electrically
CHT sensors are under plug with same wire setup |
The reason for this question is founded in
characteristics of legacy thermocouples designed
to drive stand-alone instruments. Given that
there were no wires at the instrument ends
attached to ground or other ship's wiring, the
engine thermocouples could be quite simply
constructed with the junctions literally
'grounded' to the sensor shell.
Such sensors might not play well in the modern
EFIS sandbox.
I rather suspect that everyone builds isolated
(insulated) thermocouples such that no
electrical continuity exists between the thermocouple
conductors and the sensor enclosure. These would
be functionally friendly in any engine management
system.
| Quote: | The gross excursions of reading sound more like
I have also tried it with the RDAC ground attached next to the EGT sensor but this made no difference |
When you installed this experimental ground,
were there any OTHER grounds in operation? I.e.
DC power ground? To absolutely eliminate the
possibility of this being a ground loop problem.
ALL grounds would need to go ONLY to crankcase.
However, if your thermocouples are of the
insulated variety, ground loop(s) are almost
assuredly not the problem.
Have you conversed with the manufacturer about
this?
Okay.
out of that stuff?"
Posted: Wed Feb 03, 2021 11:19 am Post subject: EFIS Erratic Temp Readings |
| Quote: | It is generated along the whole length of the wire based on the temperature gradient along the wire in question. The only reason we get anything to measure is that the two wires used in the thermocouple have different coefficients.
Not that all this is terribly pertinent in actual applications, but one should know how electrical phenomena actually work. |
That's the assertion I was having trouble with.
There are thermocouple installations in petroleum
refineries that are hundreds of feet long and
traverse a huge range of temperatures . . . if
'gradient along the length' is in play, how
can such installations offer meaningful readings
from 'the far end'?
I would draw your attention to View -B- of the
illustration I posted. It's entirely valid to
EXTEND a thermocouple any necessary distance
with two copper wires . . . as long as you KNOW
the temperature of the environment where the
transition from t/c wire to copper takes place.
That joint becomes the reference junction.
I've not encountered a situation where length
or surrounding environment of extension conductors
have an effect on calibration of a 'zero current'
thermocouple installation.
out of that stuff?"
Posted: Wed Feb 03, 2021 4:28 pm Post subject: EFIS Erratic Temp Readings |
| Quote: | | Think about it. The thermocouple that is hundreds of feet long that goes through lots of temperature transitions from one end to the other generates voltage all along its length - sometimes positive and sometimes negative, depending on the temperature gradient along that particular section. The only thing that matters is the total temperature difference between the two ends. All other intermediate transitions cancel out. It's like putting lots of batteries in series - some pointing one way and others pointing the other. The net result is just the sum of all the batteries - positive and negative adding and subtracting respectively. |
Suppose I brought 10' of chromel wire together at a
sense junction with 100' of alumel wire. Assume further
that the far ends of both wires terminate at a
temperature compensated thermocouple meter.
Suppose further than the 100' strand was coiled up and
immersed in 100C water while the 10' strand remained
at room temperature.
Is it your understanding that serious errors in
temperature reading would be generated by gross
differences in temperature dependent voltage
sources within those two wires? I.e. thermocouple
class voltages (microvolts) are generated by
warming two identical molecules of a conductor?
What is this phenomenon called? Can you point
me to literature that explains it?
out of that stuff?"
Joined: 28 Mar 2008 Posts: 1963 Location: Riley TWP Michigan
Posted: Wed Feb 03, 2021 5:17 pm Post subject: Re: EFIS Erratic Temp Readings |
One time at work I measured millivolts at the end of a two wire fire alarm cable that was buried underground.
Water had gotten into the cable and turned it into a battery.
_________________ Joe Gores |
Posted: Fri Feb 05, 2021 6:21 am Post subject: EFIS Erratic Temp Readings |
| Quote: | | Quote: | What is this phenomenon called? Can you point
me to literature that explains it? |
It is called the Seebeck effect. I previously included a link that explains the effect: tinyurl.com/3njog7qv Also refer to the links in that article for more information.
For practical purposes you can certainly continue to say that the voltage is generated at each junction and that nothing happens in between. All I am doing is explaining what actually happens.
I had to dig out references I've not consulted
for oh . . . say . . . 40 years? Even my
revered CRC Handbook of Chemistry and Physics
doesn't dig this deep into the phenomenon. But
I did find some recitations on the phenomenon
Dick brought to the conversation.
Thermocouples are but one instance where the
characteristics of materials push electrons
around. These are studies in electro-motive
physics.
There are many instances where 'differences'
in two materials encourage motion of electrons
under certain conditions.
MECHANICALLY induced electro-motion:
Shuffle your rubber soled shoes on a carpet
in dry weather and you build a potential on
your body that can produce visible sparks
when discharged to some metal object or perhaps
another person. Leather soled shoes, yeah but
not so much.
Mechanically modulated magnetic fields in
alternators and generators produce very
significant electron motion that keeps our
instrument panels lit up.
CHEMICALLY induced electro-motion:
Conductive plates pasted with two different compounds
of lead submerged in mixture of sulfuric acid will
offers a potential for flow of electrons . . .
what's more it's reversible. But if the plates
are identical, no joy.
Pieces of zinc and copper pushed into a lemon
produces a measurable voltage between the
two metals; but use two copper pieces and
the effect goes away.
THERMALLY induced electro-motion:
put any two dissimilar metals in intimate
contact with each other and they will produce
a voltage based on temperature.
I had not picked up on the phenomenon Dick
cited because it's a layer down from
the practical physics that applies to our
craft.
About 1821 this observant guy Seebeck discovered
the thermo-electric effects in a loop of two
metals wherein their joinings (junctions) were
at different temperatures. The energy flow generated
in that loop of wire was directly related to
the magnitude of temperature difference between
the two junctions. If the alloys were carefully
controlled and tiny voltages accurately measured
that energy would represent real temperatures.
Hence the foundation of the thermocouple driven
instruments spanning over a century of aviation
practice.
ELECTRICALLY induced thermo-motion:
A few years later in 1834, another sharp fellow
Peltier observed that the thermo-electric generation
was reversible. I.e. if you replaced the thermocouple
measuring instrument with a current source, those
same two junctions would assume temperatures above
and below ambient. Effects difficult to observe
due to the very tiny effects. But they were real
and could be detected.
It wasn't until years later in 1854 that another
sharp fellow Thomson identified thermo-electric
effects within conductors that explained how
Seebeck and Peltier's discoveries worked.
The longitudinal thermo-electric property
within conductors was named after Thomson. The
Seebeck, Peltier and Thomson effects combine
to complete a story of how thermocouples
function to monitor engines and thermoelectric
coolers refrigerate beer.
At the ripe age of 22, Thompson was awarded
a professorship in natural philosophy (physics).
Thompson was only 30 years old when he
identified and quantified this longitudinal
behavior of thermodynamics in a single
conductor. Thompson was better known by his
British title of station: Lord Kelvin.
Dick cited the next level down in the
physics of Seebeck and Peltier effects;
accurate but not generally included
in practical explanations for the two
technologies. It's kinda like dissecting
the physics of lubricity and viscosity
when considering suitability to task
for lubricating oils in engines.
His only error was to identify it as the
'Seebeck effect' as opposed to the
'Thomson effect'.
It was an interesting excursion to
a time when I probably should have
been paying more attention in class!
Thanks for the trip Dick!
Bob Nuckolls
AeroElectric Connection
P.O. Box 130
Medicine Lodge, KS 67104-0130
Mobile: 316-209-7528
Web: http://aeroelectric.com
out of that stuff?"
Posted: Sat Feb 06, 2021 9:37 am Post subject: EFIS Erratic Temp Readings |
| Quote: | If I only have sensor connected temperature reading is different for each “scan” and varies by up to 150 degrees between max and min.
Hope that helps |
Mike, I was reviewing this thread and another
thought occurs. While testing with 'no sensors'
what was the condition of the open inputs?
Did you put shorts across them or were they
simply disconnected?
out of that stuff?"
Posted: Sat Feb 06, 2021 12:54 pm Post subject: EFIS Erratic Temp Readings |
Sent: February 6, 2021 9:36 AM
No, they were not shorted, simply disconnected. Will try with them shorted next week.
I would never have thought of shorting them
I did remove the alternator and ran the engine with no alternator and that made no difference,
Readings were still erratic
Mike
out of that stuff?"
Posted: Sat Feb 06, 2021 2:34 pm Post subject: EFIS Erratic Temp Readings |
| Quote: | No, they were not shorted, simply disconnected. Will try with them shorted next week.
I would never have thought of shorting them |
It used to be pretty much standard that
the input to a thermocouple driven display
device was pretty low impedance. Modern
electronics allows us to resolve those
tiny voltages with displays having very
high input impedances.
I have data acquisition equipment that
requires unused channels to be 'tied down',
i.e. shorted out. Otherwise they 'wander'
in response to stimuli in the environment.
Your EFIS may be similarly designed.
Readings were still erratic |
Hmmmm . . . so probably no value in exploring
noise on the DC power line.
See what the thing does with all inputs 'locked
down' . . . then if stable . . . try adding one
t/c at a time.
out of that stuff?"
Ceengland
Posted: Sat Feb 06, 2021 4:38 pm Post subject: EFIS Erratic Temp Readings |
snipped
Mike
| Hi Mike,
Can you remind us whether the engine is 'standard' mags & carb (or Bendix style injection), or if it has some combination of electronic ignition/fuel injection?
Charlie
Posted: Mon Feb 08, 2021 11:29 am Post subject: EFIS Erratic Temp Readings |
Hi Mike,
It is a LOM engine with magneto’s only and mechanical fuel injection. No electronics on the engine at all
Mike
Charlie
Virus-free. www.avast.com
