LED question
rsmith52
PostPosted: Sun Jan 31, 2021 10:38 am    Post subject: LED question Reply with quote
I am installing dual lightspeed ignitions in my Bearhawk. 5100H1LC LEDs are speced as panel mounts to indicate when one of the ignitions is not powered. The LEDs are powered off a pin on the ignition output connectors. The LEDS are described as 1.8V low current, the red lead is indicated as positive. To test them I used a new AA battery reading 1.6V. I did not get even a faint glow, so wondering if they are bad or if they need the full 1.8V or more to produce visible output.
Rod
kjashton(at)vnet.net
PostPosted: Sun Jan 31, 2021 11:37 am    Post subject: LED question Reply with quote
The spec says “will operate off 5V to 12V without an external resistor". You just need more juice. See datasheet here https://www.digikey.com/en/products/detail/visual-communications-company-vcc/5100H1LC/59900
-Kent
Rod
PostPosted: Sun Jan 31, 2021 11:45 am    Post subject: Re: LED question Reply with quote
Do NOT test an LED with a battery without a series resistor. Otherwise the
LED will be destroyed. You did not destroy yours because the battery voltage
was not high enough. But if the battery was 1.8 volts or more, the LED would
be destroyed without a series resistor. There are online calculators to
determine the resistor value to use.
Joe Gores
PostPosted: Sun Jan 31, 2021 11:51 am    Post subject: Re: LED question Reply with quote
I was wrong and Kent is right. The 5100H1LC has a Built-in resistor chip.
But if an LED does not have a built in resistor, then one must be added.
Joe Gores
