Z101B Aux Alternator and Overvoltage protection
PostPosted: Thu Jan 21, 2021 8:14 am    Post subject: Z101B Aux Alternator and Overvoltage protection Reply with quote
IIRC, the B&C regulator that's made for the backup alt is supposed to ignore an OV event caused by the main alt, and not react to OV except from its own alt.
Protection for the B-lead would be the same whether the fuse (or breaker) is on the fat wire tie point, or on a bus. The fuse/CBÂ is protecting the wire from the battery; not the alternator.
Correct . . . but I perceive no good reason for
adding the complexity of a full-up alternator
controller to the aux alternator system.
out of that stuff?"
