Any ideas where to get electric motor brushes?
Ceengland
PostPosted: Mon Jan 04, 2021 2:50 pm    Post subject: Any ideas where to get electric motor brushes? Reply with quote
On 1/4/2021 4:11 PM, rparigoris wrote:
Hi Bob It's for a 1941 Monarch EE. It has a 5HP 3 phase AC motor that spins a 4 pole DC generator, the generator is connected to a 2 pole exciter and the DC motor is 4 pole. In 1941 they didn't know how to speed control an AC motor so they did so with a DC motor. I forget exactly the hocus pocus they are doing, it doesn't have a huge tube, but slow speed torque is quite impressive. I need exciter and generator brushes and will probably change the motor brushes as well. All 3 devices have shunt wires. How do I determine what hardness I might want? The exciter brush has 600 on it. The generator brush has 063A on it. I have a call into Monarch, but my generator and exciter may not be stock. Thx. Ron P.
I'm not Bob, but that sounds like a basic rotary phase converter; still
available to get 3 phase power from 'single phase' service. Might be
branded/made by Monarch, or sourced from a vendor that makes motors &
phase converters. Is the rotary converter built into the lathe, or a
separate component? The ones I've seen are typically separate from the
tool, and often are used to power more than one 3phase tool in the shop
(sometimes one-at-a-time, depending on converter capacity). If it's a
separate component, it should have a dataplate on it somewhere.
FWIW, solid state converters are relatively cheap these days; ex:
https://www.amazon.com/Digital-Phase-Converter-5HP-Range/dp/B07F243HLG/ref=psdc_10967761_t1_B00FF1S5IS
And if you shop around a bit, you can find a 'variable frequency drive'
that will not only give you 3 phase, but the ability to vary the rpm of
the lathe using the converter. Like this:
https://www.amazon.com/Single-Phase-Variable-Frequency-Inverter-Controller/dp/B07L8XZFYG
And no more brush worries (at least in the converter).
Charlie
Charlie
rparigoris
PostPosted: Mon Jan 04, 2021 5:17 pm    Post subject: Re: Any ideas where to get electric motor brushes? Reply with quote
Hi Charlie
My Monarch EE helped to win WW2. It was owned by the Singer Corporation until the 1970s. Back in the day, 3 phase AC motors couldn't be speed controlled. Thus Monarch has an integral 3 phase AC motor with DC Generator. At the tip of the spinning mass is an Exicter. Some Monarch also used a Magnetron tube. The idea was you could have a variable speed on the fly with good low speed torque. If you just cut voltage on a DC motor you can speed control it but low speed torque suffers. Monarch does some hocus pocus that increases torque at lower speeds compared to just cutting voltage. DC motor has 4 brushes. Today you have PWM speed controls for DC motors which can do the same thing, but back then this was a terrific desirable feature. There are many Monarchs that modify the unit by removing all this stuff and associated relays and controls and replace it with a brushless 3 phase AC motor with a speed controller. Not a trivial modification.
I power my stuff with a 7.5hp rotophase running on 220v single phase including the Monarch.
The main DC motor was rebuilt early on but the Exciter and AC/DC Generator is what was with machine when purchased from Singer.
I actually have 2 rotophase converters. One 3hp and one 7.5hp. Since the late 1970s all that I did with the Rotophase converters is put in a tiny amount of grease and replaced relays and capacitors perhaps once each.
I remember replacing all the brushes in the 1980s when I was using the machine alot. I got them from the motor rebuilder. Brushes have lasted till now. Ron P.
