Firewall Penetration Redux
jluckey(at)pacbell.net
PostPosted: Tue Dec 29, 2020 12:08 pm    Post subject: Firewall Penetration Redux Reply with quote
BobN,
A couple of weeks ago you posted a picture of a Bonanza's firewall under construction. It shows a firewall pass-thru fitting with a 90 deg bend and some sort of flange attached to firewall. What is that fitting made of?
-Jeff
Ceengland
PostPosted: Tue Dec 29, 2020 1:35 pm    Post subject: Firewall Penetration Redux Reply with quote
On 12/29/2020 2:03 PM, Jeff Luckey wrote:
BobN,
-Jeff
I'm not Bob, but stainless grab bars work well. Just find versions that have the flange welded onto the bend. I needed a straight shot off the firewall for mine, so I cut it short enough that I just had a short stub left for clamping the fire sleeve. Ebay has had smaller (~1") stainless flanged stubs in the past, but I can't find the link now.
Charlie
Charlie
PostPosted: Tue Dec 29, 2020 2:22 pm    Post subject: Firewall Penetration Redux Reply with quote
At 02:03 PM 12/29/2020, you wrote:
BobN,
Beech fabricated their fittings from stainless
steel.
out of that stuff?"
mikepienaar09(at)gmail.co
PostPosted: Wed Dec 30, 2020 12:38 pm    Post subject: Firewall Penetration Redux Reply with quote
When I installed mine I put the pipe end of the fitting inside the cockpit This is purely cosmetic, the firesleeve and sealer clamp are then out of sight
From the engine side you only see the wires bundle going into the fitting
Mike
On Dec 29, 2020, at 2:28 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
BobN,
steel.
out of that stuff?"
