Can I closely bundle 120vac with aircraft wiring?
rparigoris
PostPosted: Tue Dec 22, 2020 10:51 pm    Post subject: Can I closely bundle 120vac with aircraft wiring? Reply with quote
Hi Group I'm installing two Reiff heaters on my Rotax 914. One on the oil tank (50 watts) and one on the engine sump (100 watts). I want to closely wire the 120vac with airplane harness. There's engine sensors, Rotax TCU and sensors among other things. Can closely bundling 120vac cause any problems? Thx. Ron P.
PostPosted: Wed Dec 23, 2020 4:33 am    Post subject: Re: Can I closely bundle 120vac with aircraft wiring? Reply with quote
There will not be a problem running AC wires near DC wires.
[as long as the AC is unplugged before flying Smile ]
Use heat conductive paste between the oil tank and heating band.
My engine heat pad failed because it had trouble adhering to the curved surface.
Joe Gores
