Mallard
Posted: Mon Dec 14, 2020 4:52 pm Post subject: Possible Leaking Fuel Tank! |
Dear All, Urgent help required. Today I discovered about half a litre of fuel pooled in the baggage footwell behind the pilot’s seat which had wicked up to the carpeting. The fuel is exiting the aircraft where some bolts pass through the fuselage.
The fuel cock was not in the “Off” position so I turned it off. I removed the port inspection cover in the baggage area to see if any of the fuel hoses showed any obvious signs of leaking. There was some fuel on the floor of the inspection hatch but not signs of fuel leaking. I then mopped up the fuel in the baggage footwell and observed that fuel appeared to still be leaking into the area and coming from the base of the fuel tank.
It may be that the main fuel tank is leaking and may require replacement.
Has anyone got experience of this problem and how was it solved?
Thankyou very much in advance for any & all advice.
James
236.38 KB |
17042 Time(s) |
145.06 KB |
17042 Time(s) |
202.19 KB |
17042 Time(s) |
_________________ Seat of my pants |
rlborger(at)mac.com Guest
Posted: Mon Dec 14, 2020 5:12 pm Post subject: Possible Leaking Fuel Tank! |
James,
I am quite familiar with the problem. I replaced my fuel tank back in 2014.
You can read about it and view pictures of the work at: http://www.europaowners.org/main.php?g2_itemId=60232&g2_page=3
Click on the preview picture “Fuel Tank Replacement.”
Bud Yerly has a document outlining the replacement of the fuel tank on his website: customflightcreations.com
It is under the “Techniques Articles and Build Information” subject.
There are probably a number of others who have gone through this situation and can also provide helpful information.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop.Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop.3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com) | Quote: | On Dec 14, 2020, at 6:52 PM, Mallard <james(at)kingdom.ie (james(at)kingdom.ie)> wrote:
--> Europa-List message posted by: "Mallard" <james(at)kingdom.ie (james(at)kingdom.ie)>Dear All, Urgent help required. Today I discovered about half a litre of fuel pooled in the baggage footwell behind the pilotâs seat which had wicked up to the carpeting. The fuel is exiting the aircraft where some bolts pass through the fuselage.The fuel cock was not in the âOffâ position so I turned it off. I removed the port inspection cover in the baggage area to see if any of the fuel hoses showed any obvious signs of leaking. There was some fuel on the floor of the inspection hatch but not signs of fuel leaking. I then mopped up the fuel in the baggage footwell and observed that fuel appeared to still be leaking into the area and coming from the base of the fuel tank.It may be that the main fuel tank is leaking and may require replacement. Has anyone got experience of this problem and how was it solved? Thankyou very much in advance for any & all advice.James--------Seat of my pantsRead this topic online here:http://forums.matronics.com/viewtopic.php?p=499671#499671Attachments: http://forums.matronics.com//files/fuel_leak_baggage_footwell_image_no_1_141220_132.jpg
aspenbuild(at)me.com Guest
Posted: Mon Dec 14, 2020 7:53 pm Post subject: Possible Leaking Fuel Tank! |
Hi James,
You need to go to the Europa club website. Bud Yearly in the US has done a great ‘how to ‘ guide on this and recently donated all this work to the club, plenty of info out there.
Richard
James
Seat of my pants
Dave Disney
Joined: 16 Aug 2010 Posts: 54 Location: Weston-Super-Mare
Posted: Thu Dec 17, 2020 6:26 am Post subject: Re: Possible Leaking Fuel Tank! |
Hi James,
Sorry to hear that you may have a leaking fuel tank. I had had this problem back in 2017 but I didn't change the fuel tank even though I found that the tank had split causing the leak.
First of all you need to establish where the fuel is leaking from, sounds simple but took me ages. Once you have established that the tank has failed, I would suggest you first look at my repair scheme before you go to the trouble and expense of replacing the tank. You will see from the links in previous posts that replacing the tank isn't a small job.
My repair may be suitable for your tank if you have a similar problem to mine, it has held up for over 4 years now with no sign of deterioration.
Contact me off-line if you want further information, I'm happy to help if I can, I have tons of photos and the repair scheme which was approved by the LAA in the UK.
Dave
G-RJWX
diamond
Posted: Fri Dec 25, 2020 5:57 am Post subject: Re: Possible Leaking Fuel Tank! |
I agree, check first where the leak does come from. I took me 2 years
but I would have find the origin of my problems : The cork gasket above the tank was completely falling apart. This after various hose leaks.
I used an colored UV light tracer to mix in the fuel, very usefull.
Obviously I now advise everyone to check the condition of this seal, which also made a lot of deposits in the tank. The service life is not more than five or 10 years
wdaniell.longport(at)gmai Guest
Posted: Fri Dec 25, 2020 3:27 pm Post subject: Possible Leaking Fuel Tank! |
I installed a fuel sender during the build. 12 years later we noticed green streaks on the belly on landing Panama City from Medellin After taking off the wings ( with visions of a cracked tank)...we discovered that it was the fuel sender gasket which had perished during the 10 year build.
William Daniell
+1 786 878 0246
On Fri, Dec 25, 2020, 09:00 diamond <emanu(at)gmx.fr (emanu(at)gmx.fr)> wrote:
| Quote: | --> Europa-List message posted by: "diamond" <emanu(at)gmx.fr (emanu(at)gmx.fr)>
http://forums.matronics.com/viewtopic.php?p=499803#499803
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
Mallard
Posted: Tue Jan 12, 2021 12:33 pm Post subject: Re: Possible Leaking Fuel Tank! |
This is an update on my fuel leak for anyone who is interested.
At the weekend an LAA Inspector went to my aircraft and as a result of his investigation, he discovered that the Fuel Pipe from the Fuel Tank Starboard Sump to the Starboard Fuel Drain had literally disintegrated at a point where there was an elbow in the pipe. He described the pipe as having gone very soft, so soft it had the consistency of Spaghetti & there was a hole in it, through which you could stick your finger!
My next task is to replace all the Fuel & Coolant Pipes because they haven't been replaced since aircraft was built 10 years ago.
As my aircraft has a 914 engine there is more pipe work than in a 912S.
Has anyone replaced all the Fuel Pipes in a 914 and if so, would you have a detailed description of the easiest way to go about the task?
Thanks to all who responded to my original query and to those who may respond again.
Regards and Happy New Year to everyone.
James
SteveIvell(at)pestproof.c Guest
Posted: Tue Jan 12, 2021 2:51 pm Post subject: Possible Leaking Fuel Tank! |
Hi James
You only have an extra oil line to the turbo so it's virtually the same job as a 912.
Make sure you get some long reach pipe clamp wrench. It makes the job much easier.
[img]data:image/png;base64,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
peterz(at)zutrasoft.com Guest
Posted: Tue Jan 12, 2021 3:29 pm Post subject: Possible Leaking Fuel Tank! |
Wow...where does one find a tool like that!?
Pete C-GNPZ
| Quote: | On Jan 12, 2021, at 6:00 PM, Steve Ivell <SteveIvell(at)pestproof.co.uk> wrote:
Hi James
You only have an extra oil line to the turbo so it's virtually the same job as a 912.
Make sure you get some long reach pipe clamp wrench. It makes the job much easier.
[img]data:image/png;base64,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
Mallard
Posted: Tue Jan 12, 2021 4:33 pm Post subject: Re: Possible Leaking Fuel Tank! |
Steve,
Attached is the Fuel System Schematic for my aircraft.
| G-FITY Fuel System Schematic |
G-FITY - Fuel System Schematic _Correct drawing_ 12.01.21.pdf |
66.79 KB |
606 Time(s) |
_________________ Seat of my pants |
Mallard
Posted: Tue Jan 12, 2021 4:53 pm Post subject: Re: Possible Leaking Fuel Tank! |
Steve,
66.79 KB |
698 Time(s) |
Mallard
Monoman
Posted: Wed Jan 13, 2021 2:00 am Post subject: Re: Possible Leaking Fuel Tank! |
Further to the leaking fuel tank thread, I am also just about to replace all fuel and oil hoses. Can anyone tell me roughly what length of the various hoses to order?
I have a classic with 80HP Rotax.
Mike
G DURO
m.j.gregory(at)talk21.com Guest
Posted: Thu Jan 14, 2021 9:47 am Post subject: Possible Leaking Fuel Tank! |
James,
Warning! While a pipe clamp can be very useful to stop fuel going all over the place while working with flexible pipes, please be very careful when using it, either during installation or later in service. Ensure that the clamp you use has smooth round (at least 1/4 inch diameter) jaws and apply no more pressure than is needed to stop the fuel flow – do not crush the pipe.
Andy Draper of the LAA has warned that the action of clamping can lead to internal break-up of the tube material, making debris in the system and leakage. This is all the more dangerous because the clamp may leave no sign of damage that an external inspection might pick up before trouble occurs.
Pete Jeffers offers the advice that replacement is best done by removing each pipe in turn, cutting the new piece to match the length, then fitting it and securing both ends before disconnecting the next one. This way you avoid the possibility of making a mistake by cross-connection. Double check that you are fitting fuel filters the correct way round, matching the arrow marking with the direction of flow. There should be no tight radii or kinks, and pipes should be secured so that they do not flop around (but do not tie them to electrical cables!).
When all the new pipes are in place and you have checked all connections for tightness, flush the system through by disconnecting the carburettors and operating the pumps to feed fuel into a suitable container, until you are sure there is no debris remaining. For complete peace of mind, as recommended by your inspector, carry out full system flow and pressure tests in accordance with the Europa engine installation manual. For the Rotax 914, the instructions are in the Europa XS Rotax 914 Engine Manual Issue 7 June 2004 Page 9 – 3.
Further information is available from the Rotax website https://www.rotax-owner.com/en/support-topmenu/engine-manuals#914-series-engines, from which you can download installation and maintenance manuals.
For a UK owner, the replacement of hoses and subsequent system checks should be signed off by your LAA inspector. If you wish to make any changes to the system while you are replacing the pipes, the LAA inspector may approve the routing, but any changes to system configuration that differ from the manual or an approved modification would require LAA approval.
Hope this helps.
Mike
Dr Mike Gregory
Europa Club Safety Officer
01480 451655
07885 355765
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Steve Ivell
Sent: 12 January 2021 22:50
To:
Subject: Re: Re: Possible Leaking Fuel Tank!
Hi James
You only have an extra oil line to the turbo so it's virtually the same job as a 912.
Make sure you get some long reach pipe clamp wrench. It makes the job much easier.
Also don't be afraid to remove the intake manifolds of the top of the engine. They are sealed by rubber o rings so no gaskets to worry about.
Good luck.
Kind Regards
Steve Ivell
GSTES
90% Finished.....90% left to do!!
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> on behalf of Mallard <james(at)kingdom.ie (james(at)kingdom.ie)>
Sent: Tuesday, January 12, 2021 8:33:26 PM
To: europa-list(at)matronics.com (europa-list(at)matronics.com) <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Subject: Re: Possible Leaking Fuel Tank!
--> Europa-List message posted by: "Mallard" <james(at)kingdom.ie (james(at)kingdom.ie)>
This is an update on my fuel leak for anyone who is interested.
At the weekend an LAA Inspector went to my aircraft and as a result of his investigation, he discovered that the Fuel Pipe from the Starboard Sump to the Starboard Fuel Drain had literally disintegrated at a point where there was an elbow in the pipe. He described the pipe as having gone very soft, so soft it had the consistency of Spaghetti & there was a hole in it, through which you could stick your finger!
My next task is to replace all the Fuel & Coolant Pipes because they haven't been replaced since aircraft was built 10 years ago.
Since my aircraft has a 914 engine there is more pipe work than in a 912S.
Has anyone replaced all the Fuel Pipes in a 914 and if so, would you have a detailed description of the easiest way to go about the task?
Thanks to all who responded to my original query and to those who may respond again.
Regards and Happy New Year to everyone.
James
Seat of my pants
http://forums.matronics.com/viewtopic.php?p=500161#500161
Virus-free. www.avg.com
130.65 KB |
16678 Time(s) |
350 Bytes |
16678 Time(s) |
Mallard
Posted: Tue Jul 20, 2021 5:43 am Post subject: Re: Possible Leaking Fuel Tank! |
Final Update on what caused the fuel leak in my Mono XS!
Below is the report from the LAA Inspector Engineer:
Found the fuel hose issue today, see pictures attached. The issue was the rudder cable sawing away at the hose, it all gets very congested in the tunnel between the seats. Where the hose goes in and out of the seat pan, there can only be a 6 mm gap between the hoses and the cables. This is where the cable has cut into the hose as the hose goes into a tee for one leg to the engine (fuel bleed off return) - one to the rear mounted drain and the third leg to the tank outlet connection. It was the last one that had the hole.
1.29 MB |
15139 Time(s) |
1.3 MB |
15139 Time(s) |
Fred Klein
Posted: Tue Jul 20, 2021 8:24 pm Post subject: Possible Leaking Fuel Tank! |
one thing I don’t regret was running my rudder cables within teflon tubing
budyerly@msn.com
Posted: Wed Jul 21, 2021 7:05 am Post subject: Possible Leaking Fuel Tank! |
I am not intending to point fingers. Please do not take offense:
Frankly, I'm shocked the inspector didn't find such a flagrant problem during the normal build inspection and post build inspection process.
Wiring, hoses, cables, and mechanisms must be checked for proper clearances during the build, after any maintenance and especially after a hose change.
One must anticipate that gravity works 24/7 and hoses and wiring must be secured to prevent any conflict with any moving object, control or cable. We have all been bitten by this conflict between components and must carefully inspect our work and that of others to prevent such incidents.
Attention to detail is essential. A quick flashlight look around is not an inspection. Good enough is not always good. Of course, as Ira Rampil quoted one of his professors "The enemy of good is better" and one can get too carried away with overthinking a cable to hose clearance/securing issue when a simple zip tie fix or making a standoff out of zip ties and plastic tubing/fairlead on a cable can be done in minutes! In my experience, a cable can be manufactured in a few minutes. If the cable run has not been done right, or there are areas of concern with wires and cables near the rudder cables, cut the cable and make a new one with some tubing for protection and just be done with it.
Fred's comments are true. Plastic tubing over your cables is neat, smart and prevents inadvertent interference running cables around the fuselage. I run cables in tubing from the firewall, back to the pulley and then as far back as I can in the rear of the fuselage. Put an Adel clamp or plastic P clip on the tube and never worry about the cable chafing or slapping around. Clean quiet and neat if done properly (i.e. run the cables straight and don't use the tubing for bending the cable around items where a pulley is the proper answer.
Just my thoughts,
Bud Yerly
Griffo
Joined: 18 Mar 2021 Posts: 70 Location: The Oaks, NSW, Australia
Posted: Sat Jul 24, 2021 1:31 am Post subject: Re: Possible Leaking Fuel Tank! |
I dont seem to be able to view this one conversation - is it just me/my computer or have others found there is a problem?
_________________ 46 |
