912ULS fuel return line orifice size
peterz(at)zutrasoft.com
PostPosted: Fri Dec 04, 2020 4:40 am    Post subject: 912ULS fuel return line orifice size Reply with quote
Hi Folks,
I'm currently re-doing my fuel lines and configuration and have discovered my return orifice was made at 1/32" or 0.68mm which is twice the size of the spec'd rotax 0.33 mm or 1/64".  It may explain why whenever I turned the electric pump off the pressure would drop to near zero for a couple seconds before recovering to the expected 4-5psi.
Curious what size other folks are running? 0.33mm?
Cheers and thanks,
Pete Z.
brian.davies44(at)gmail.c
PostPosted: Fri Dec 04, 2020 5:22 am    Post subject: 912ULS fuel return line orifice size Reply with quote
Hi Pete
If you are running the latest mechanical fuel pump I think you will find that Rotax have published information that states a brief drop in fuel pressure is “normal”.  I have never understood why this should be “normal” but…
I don’t think it is linked to the size of the return line orifice.
Brian
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Pete Zut
Sent: 04 December 2020 12:40
To: europa-list <europa-list(at)matronics.com>
Subject: 912ULS fuel return line orifice size
Hi Folks,
Cheers and thanks,
Pete Z.
PostPosted: Fri Dec 04, 2020 5:48 am    Post subject: 912ULS fuel return line orifice size Reply with quote
Many thanks Brian for the info..... I'm relieved to hear that others are
seeing the same, and that Rotax actually published something on it.
Cheers and blue skies Smile
(and I'm leaving the orifice as per the Europa size)
On Fri, Dec 4, 2020 at 8:30 AM Brian Davies <brian.davies44(at)gmail.com>
wrote:
[quote] Hi Pete
but…
