kitfox555(at)sbcglobal.ne Guest
Posted: Thu Nov 19, 2020 10:17 pm Post subject: Get temps |
I have a 90 grey head I forgot the temp I should at 5500 rpm 1050. Or 1100 top is 1200 anyone know for sure thanks Jerry. Kitfox 2. 555
genie(at)swissmail.org Guest
Posted: Thu Nov 19, 2020 11:42 pm Post subject: Get temps |
Could you please enlighten me on what kind of engine you have on your
Kitfox 2. And on what units you use for temperature. Thank you.
George
On 20-Nov-20 7:16, Jerold EVANS wrote:
Posted: Fri Nov 20, 2020 7:16 am Post subject: Get temps |
1990 Rotax 582 two-stroke exhaust gas temperature at the exhaust header
| Quote: | On Nov 19, 2020, at 11:48 PM, George Nielsen <genie(at)swissmail.org> wrote:
Could you please enlighten me on what kind of engine you have on your Kitfox 2. And on what units you use for temperature. Thank you.
George
> Sent from my iPhone
Posted: Fri Nov 20, 2020 7:30 am Post subject: Get temps |
In degrees Fahrenheit, I presume.
On 20-Nov-20 16:15, Jerold EVANS wrote:
> George
>> Sent from my iPhone
Posted: Fri Nov 20, 2020 7:49 am Post subject: Get temps |
Yes Fahrenheit in degrees
| Quote: | On Nov 20, 2020, at 7:37 AM, George Nielsen <genie(at)swissmail.org> wrote:
> Sent from my iPhone
>> George
>>> Sent from my iPhone
Posted: Fri Nov 20, 2020 7:52 am Post subject: Get temps |
| Quote: | On Nov 20, 2020, at 7:48 AM, Jerold EVANS <kitfox555(at)sbcglobal.net> wrote:
>> Sent from my iPhone
>>> George
>>>> Sent from my iPhone
1.06 MB |
12114 Time(s) |
Posted: Fri Nov 20, 2020 8:23 am Post subject: Get temps |
Jerry, allow me to recap the situation: You have a Kitfox 2 with a 1990
Rotax 582 (presumably air cooled) two-cylinder two-stroke engine, you
measure the exhaust gas temperature at the exhaust header and want to
know whether at 5500 rpm the temperature should be 1050 or 1100 or a
maximum of 1200 degrees Fahrenheit. Did I get it right?
On 20-Nov-20 16:48, Jerold EVANS wrote:
>> Sent from my iPhone
>>> George
>>>> Sent from my iPhone
Posted: Fri Nov 20, 2020 9:05 am Post subject: Get temps |
Water cooled
| Quote: | On Nov 20, 2020, at 8:29 AM, George Nielsen <genie(at)swissmail.org> wrote:
Jerry, allow me to recap the situation: You have a Kitfox 2 with a 1990 Rotax 582 (presumably air cooled) two-cylinder two-stroke engine, you measure the exhaust gas temperature at the exhaust header and want to know whether at 5500 rpm the temperature should be 1050 or 1100 or a maximum of 1200 degrees Fahrenheit. Did I get it right?
> Sent from my iPhone
>>> Sent from my iPhone
>>>> George
>>>>> Sent from my iPhone
Pat Reilly
Posted: Fri Nov 20, 2020 3:33 pm Post subject: Get temps |
Jerold, You have it right. I have the same engine and gages. I just
remember that I'm good until the gage needles go past each other (1200
degrees) on the way up. I don't know if this explanation makes sense to
you. I think the gages were designed that way on purpose.
Pat Reilly
Rocford, IL
On Fri, Nov 20, 2020 at 9:13 AM Jerold EVANS <kitfox555(at)sbcglobal.net>
wrote:
Water cooled
>> Sent from my iPhone
header
>>>> Sent from my iPhone
>>>>> George
