Nanchang elevator balance
glipaz
PostPosted: Sat Nov 14, 2020 3:20 pm    Post subject: Nanchang elevator balance Reply with quote
On my Nanchang the elevator rests in the full up position with the stick all the way back. In flight it is perfectly balanced. I checked the balance bar and it does not have any weight plates to remove. It only has the solid balance cube. So, I contemplate removing the cube and shaving it to reduce the weight. Any suggestions?
Gil
 Filesize:  2.48 MB
 Viewed:  2673 Time(s)
 Filesize:  2.96 MB
