Swagelok
jay-dub
PostPosted: Sat Oct 31, 2020 3:24 pm    Post subject: Swagelok Reply with quote
Please could someone tell me the spec of the Swagelok valves to replace the normal and emergency air valves.
Also, the snot valves.
Thanks from Lockdown, UK. Rolling Eyes
CJ owner
pennington.construction.i
PostPosted: Sat Oct 31, 2020 3:44 pm    Post subject: Swagelok Reply with quote
Jay
I use the all stainless steel valves the Doug supplies.
The photo is from a Yak list post from before.
I hung onto it in the event I couldn’t get a Chinese stainless valve.  This is the valve for the main and emergency valves.
Mark
N621CJ
[img]cid:175810a6162a44d93281[/img]
[img]cid:175810a6bcd40077f272[/img]
On Sat, Oct 31, 2020 at 7:31 PM jay-dub <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> wrote:
--> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com (flyjnw(at)gmail.com)>
Thanks from Lockdown, UK.  [Rolling Eyes]
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=499045#499045
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
 Filesize:  373.14 KB
 Viewed:  9695 Time(s)
 Filesize:  285.26 KB
jay-dub
PostPosted: Sat Oct 31, 2020 3:46 pm    Post subject: Re: Swagelok Reply with quote
Perfect, thanks.
CJ owner
wamflight(at)gmail.com
PostPosted: Sat Oct 31, 2020 3:54 pm    Post subject: Swagelok Reply with quote
And the sizes we need to tap the threads?
On Nov 1, 2020, at 8:42 AM, Mark Pennington <pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)> wrote:
Jay
Mark
N621CJ
<IMG_4522.jpg>
<IMG_4521.jpg>
--> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> Please could someone tell me the spec of the Swagelok valves to replace the normal and emergency air valves. Also, the snot valves. Thanks from Lockdown, UK. [Rolling Eyes] -------- CJ and Yak-52 owner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499045#499045 =========== List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer" target="_blank">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ===========
k7wx
Here is a picture of my CJ emergency on-off valve with adaptors that duplicate the original line positions. The Yak-52 probably requires different adaptors. The black handle valve for the main air is Swagelok part number SS-42GF2-A-WN2 and the emergency air red handle part number is SS-42GF2-A-RD-WN2. I suggest placing about 4 turns of nylon tape on the threads to lessen the likelihood of leaks. Replace and forget.
Warren Hill
N464TW
Mesa, AZ
[img]cid:EAE9B400-E834-43EA-9F8E-4560C6ABBEC3(at)Home[/img]
On Oct 31, 2020, at 4:24 PM, jay-dub <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> wrote:
--> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com (flyjnw(at)gmail.com)>Please could someone tell me the spec of the Swagelok valves to replace the normal and emergency air valves.Also, the snot valves.Thanks from Lockdown, UK. [Rolling Eyes]--------CJ and Yak-52 ownerRead this topic online here:http://forums.matronics.com/viewtopic.php?p=499045#499045
 Filesize:  244.06 KB
 Viewed:  9685 Time(s)
PostPosted: Sat Oct 31, 2020 4:02 pm    Post subject: Swagelok Reply with quote
did you tap the new valve? size?
On Nov 1, 2020, at 8:53 AM, Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> wrote:
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
hill(at)doctor-hill.com
PostPosted: Sat Oct 31, 2020 4:10 pm    Post subject: Swagelok Reply with quote
Both the Chinese adaptors and the Swagelok valves are ⅛-27 NPT pipe thread.
On Oct 31, 2020, at 5:01 PM, William Geipel <wamflight(at)gmail.com (wamflight(at)gmail.com)> wrote:
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
PostPosted: Sun Nov 01, 2020 2:27 am    Post subject: Swagelok Reply with quote
Jay
Here is a photo I saved of the snot valve with a swagelock valve.
At the time the post did not give a part number.
Maybe someone will recognize the valve and share the part number
Mark
N621 CJ
[img]cid:1758357376d6cd9bb2a1[/img]
On Sat, Oct 31, 2020 at 8:14 PM Warren Hill <hill(at)doctor-hill.com (hill(at)doctor-hill.com)> wrote:
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
CJ and Yak-52 owner
 Filesize:  301.16 KB
 Viewed:  9660 Time(s)
hkgibby(at)yahoo.com
PostPosted: Sun Nov 01, 2020 5:56 am    Post subject: Swagelok Reply with quote
See RPA Library...click on CJ-6 Nanchang; it’s there.
On Nov 1, 2020, at 2:40 AM, Mark Pennington <pennington.construction.inc.1(at)gmail.com> wrote:
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
CJ and Yak-52 owner
k7wx
PostPosted: Sun Nov 01, 2020 7:05 am    Post subject: Swagelok Reply with quote
Hello Mark,
For the Yak-52, it's the Swagelok SS-43GM4-S4.
For the CJ, a typical install requires a right angle adaptor and a different right angle Swagelok valve. If you need this part number I’ll get it later today.
Attached are some images.
Warren
N464TW
[img]cid:509517C5-0E6C-409C-9782-356E707CC9F2[/img] [img]cid:B8602EEA-ACEA-4B48-8640-02C3B6906E5B[/img]
On Nov 1, 2020, at 3:26 AM, Mark Pennington <pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)> wrote:
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
 Filesize:  357.51 KB
 Viewed:  9645 Time(s)
 Filesize:  384.2 KB
k7wx
PostPosted: Sun Nov 01, 2020 8:49 am    Post subject: Swagelok Reply with quote
One additional item. If not already done. The bottom thread of the snot bottle will need to be tapped to accept the input side of the Swagelock valve, which I believe is ¼-inch NPT. After completing the tap, be sure to completely wash out the many small metal fragments produced. It’s helpful to do the tap a little less than you think is needed and then screw int the Swagelock valve until it is tight. If a ¼ to ½ turn more is needed to properly align the value, run the tap just a little more. This way the final valve position will not end up at some odd angle.
Hello Mark,
Warren
N464TW
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
 Filesize:  357.51 KB
 Viewed:  9639 Time(s)
 Filesize:  384.2 KB
PostPosted: Sun Nov 01, 2020 8:58 am    Post subject: Swagelok Reply with quote
Thank you Mr.  Hill
On Sun, Nov 1, 2020 at 11:55 AM Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> wrote:
Hello Mark,
Warren
N464TW
[img]cid:17584bd5436ef8af8151[/img]     [img]cid:17584bd54367a877b712[/img]
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
CJ and Yak-52 owner
 Filesize:  384.2 KB
 Viewed:  9637 Time(s)
 Filesize:  357.51 KB
