CJ-6 flap issue
cjaviator
PostPosted: Thu Oct 08, 2020 11:39 pm    Post subject: CJ-6 flap issue Reply with quote
Hi all,One of the CJ's we look after has an annoying trait in that when the aircraft has been sitting for a while and the air has bled off out of the system the flaps come down.
As soon as air pressure is restored the flaps come back up. They function normally and we cannot work out why it is doing it.
Have had flap actuator apart as part of routine inspections with no issues noted, both diverter valves apart (again no issues and they appear to be installed with correct orientation).
Any thoughts?
Regards, Jay
New Zealand
dsavarese0812(at)bellsout
PostPosted: Fri Oct 09, 2020 2:55 am    Post subject: CJ-6 flap issue Reply with quote
Jay,
What happens if you put both flap handles in the neutral position when you leave the airplane and let it set for a period of time? Do the flaps drop down?
You may have a main air valve leaking or the B nuts at the main air valve or at the main air tank leaking. Pay particular attention to the flares on the tubing under the B nuts because they are prone to cracking because of over-tightening. Use the soapy water spray test on the fittings to see if there are any leaks. The main air valve may be suspect as well.
Have you rebuilt the check valves on the firewall?
In your post you said the diverter valves and the flap actuator were taken apart and inspected with no issues noted. But have you actually overhauled them? Although you may not see anything defective during a disassembly, like for example the internal seals, they could easily be worn and allowing air to bleed past them. How long ago were the diverter valves and the flap actuator overhauled with new internal components?
Dennis
On Friday, October 9, 2020, 3:41:10 AM EDT, Jay McIntyre <cjaviator(at)gmail.com> wrote:
Any thoughts?
Regards, Jay
New Zealand
pennington.construction.i
PostPosted: Fri Oct 09, 2020 3:21 am    Post subject: CJ-6 flap issue Reply with quote
Jay
Dennis has good suggestions.   I would ask, how far down does the flap travel.  If it is dropping down more than 1/2 inch check your flap bungee.   I had to replace mine, it looked fine, but on a very close inspection I found many of the strands of rubber broken in several places.   Hope this helps.   I know that Doug stocks the parts.
Mark
N621CJ
On Fri, Oct 9, 2020 at 6:59 AM A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Jay,
Dennis
On Friday, October 9, 2020, 3:41:10 AM EDT, Jay McIntyre <cjaviator(at)gmail.com (cjaviator(at)gmail.com)> wrote:
Any thoughts?
Regards, Jay
New Zealand
rmhou(at)yahoo.com
PostPosted: Fri Oct 09, 2020 7:50 am    Post subject: CJ-6 flap issue Reply with quote
Isn't the bungee cord supposed to keep the flap up when air is depleted? Just a thought Smile
Sent from Yahoo Mail on Android
On Fri, Oct 9, 2020 at 4:34, Mark Pennington
<pennington.construction.inc.1(at)gmail.com> wrote:
Jay
Mark
N621CJ
Jay,
Dennis
Hi all,One of the CJ's we look after has an annoying trait in that when the aircraft has been sitting for a while and the air has bled off out of the system the flaps come down.As soon as air pressure is restored the flaps come back up. They function normally and we cannot work out why it is doing it.Have had flap actuator apart as part of routine inspections with no issues noted, both diverter valves apart (again no issues and they appear to be installed with correct orientation).
Any thoughts?
Regards, JayNew Zealand
cjpilot710(at)aol.com
PostPosted: Fri Oct 09, 2020 3:25 pm    Post subject: CJ-6 flap issue Reply with quote
There should be a bungee cord that would hold the flap up.
Any thoughts?
Regards, Jay
New Zealand
stephen.hayne
PostPosted: Mon Nov 23, 2020 12:28 pm    Post subject: Re: CJ-6 flap issue Reply with quote
I'm late to this party, but I had this problem for a year, and finally just replaced the bungee - problem sorted... Smile
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp
