Toe brakes and passenger brakes
gregsmi
PostPosted: Thu Oct 08, 2020 12:23 pm    Post subject: Toe brakes and passenger brakes Reply with quote
I sold one of my Pulsars and the new owner would like to take flying lessons. He would like to convert to toe brakes and also install brakes for his instructor. I know we have owners that have done one or both. I sure would like pictures of your installations. Please forward any info along. I appreciate it. The new owner did his first flight with his instructor today and he is excited.
Greg
phil(at)ishml.com
PostPosted: Thu Oct 08, 2020 3:13 pm    Post subject: Toe brakes and passenger brakes Reply with quote
Search for “toe” in the photo section of the site. You’ll find my toe brake retrofit…utilizes the original rudder pedals. Mine only cover the left seat, easily adapted for the right.
Phil
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Greg Smith
Sent: Thursday, October 8, 2020 3:21 PM
To: pulsar-list(at)matronics.com
Subject: Toe brakes and passenger brakes
Greg
myrontruex(at)comcast.net
PostPosted: Fri Oct 09, 2020 1:01 am    Post subject: Toe brakes and passenger brakes Reply with quote
I think it might have been Lisa Turner that made the first sets. I got a set from someone but later changed the brakes out to the larger ones and went back to the heel brakes. Marting had band brakes and could smoke his tires so I doub’t it was he.
30TX
Myron
From: owner-pulsar-list-server(at)matronics.com <owner-pulsar-list-server(at)matronics.com> On Behalf Of Phil Ishmael
Sent: Thursday, October 8, 2020 7:12 PM
Subject: RE: Toe brakes and passenger brakes
Phil
From: owner-pulsar-list-server(at)matronics.com (owner-pulsar-list-server(at)matronics.com) [mailto:owner-pulsar-list-server(at)matronics.com (owner-pulsar-list-server(at)matronics.com)] On Behalf Of Greg Smith
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Greg
MikeyC
PostPosted: Fri Oct 09, 2020 1:40 pm    Post subject: Toe brakes and passenger brakes Reply with quote
Hi Greg.  I dug these up from the archives.  I also ditched the cherry juice for DOT 4, which can handle higher temps.
Be advised, there’s absolutely no coverage in any of the build manuals that I know of, for this modification.  Though it’s not particularly difficult for an experienced builder, I would advise anyone attempting this to get some help from tech counselors or similarly qualified personnel.
Best, Mike
[img]cid:1750f479371e5a88d5c1[/img]
[img]cid:1750f47ccd83052b25d2[/img]
On Fri, Oct 9, 2020 at 5:05 AM <myrontruex(at)comcast.net (myrontruex(at)comcast.net)> wrote:
30TX
Myron
From: owner-pulsar-list-server(at)matronics.com (owner-pulsar-list-server(at)matronics.com) <owner-pulsar-list-server(at)matronics.com (owner-pulsar-list-server(at)matronics.com)> On Behalf Of Phil Ishmael
Phil
Subject: Pulsar-List: Toe brakes and passenger brakes
Greg
 Filesize:  1.86 MB
 Viewed:  7144 Time(s)
 Filesize:  1.78 MB
Mike Cowan
gregsmi
PostPosted: Fri Oct 09, 2020 2:25 pm    Post subject: Toe brakes and passenger brakes Reply with quote
Thanks Mike, appreciate the pictures. The new owner is a retired A&P so he will do well.
Greg
 Filesize:  1.78 MB
 Filesize:  1.86 MB
rickyd54(at)gmail.com
PostPosted: Fri Oct 09, 2020 4:18 pm    Post subject: Toe brakes and passenger brakes Reply with quote
If installing toe brakes, remember you have to consider the higher loads on the rudder cables and rudder when you apply the brakes. The standard setup will not handle those loads. I attached a pulley in the center of the front seat bulkhead and using a cable attached to the rudder pedals through the pulley. When applying brakes the pulley gets the extra load.
[quote] On Oct 9, 2020, at 4:45 PM, Michael Cowan <mikey.flyer53(at)gmail.com> wrote:
