barp99(at)gmail.com Guest
Posted: Thu Oct 01, 2020 3:45 pm Post subject: W20 Bracket spec |
I am currently attaching the port flap to the wing on my trigear, I
find, for whatever reason, that the W20 bracket is too short by 12mm
when the flap is in its correct position. Rather than live with this
mismatch at the bolted joint, I will make up a new longer W20 bracket.
Does anyone know what grade and temper these aluminium brackets are made
from?
Brian
Sydney, Aus.
61.33 KB |
7002 Time(s) |
Patrick Tunney
Posted: Fri Oct 02, 2020 11:58 am Post subject: Re: W20 Bracket spec |
Brian
I am not 100% sure but i think its Duralumin
Im sure plenty of builders have had issues with flap hinge alignment.
John Wighton
Posted: Sat Oct 03, 2020 12:15 am Post subject: Re: W20 Bracket spec |
Use a minimum of 6061 T6, probably 2024 T3 will be readily available and gives slightly higher UTS.
_________________ John Wighton
Europa XS trigear G-IPOD |
Duncan McFadyean
Posted: Sat Oct 03, 2020 12:56 am Post subject: W20 Bracket spec |
H30, I believe. But why not ask the Factory what they use now?
Duncan McF. | Quote: | On 02 October 2020 at 00:30 Brian Phillips <barp99(at)gmail.com (barp99(at)gmail.com)> wrote:
from?
Brian
Sydney, Aus. |
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Sat Oct 03, 2020 7:20 am Post subject: Re: W20 Bracket spec |
It's now 25 years since I built my Classic wings with the foam cores and I honestly can't remember the finer details, but are all the W20 brackets on each wing the same size, or are they made progressively smaller from inboard to outboard?
wdaniell.longport(at)gmai Guest
Posted: Sat Oct 03, 2020 5:38 pm Post subject: W20 Bracket spec |
BrianIt looks to me as thought the lower surface of the flap is not aligned with the lower surface of the wing...or is it just how it looks in the photo?
Will
William Daniell
LONGPORT
+57 310 295 0744
On Thu, Oct 1, 2020, 19:49 Brian Phillips <barp99(at)gmail.com (barp99(at)gmail.com)> wrote:
from?
Brian
Sydney, Aus.
Posted: Sun Oct 04, 2020 1:41 am Post subject: W20 Bracket spec |
William, I think its just the photo, I put a rule on the lower surface and checked the intersection, its hard to tell for sure but its very close to being laminar.
Brian.
On 4/10/2020 12:36 pm, William Daniell wrote:
| Quote: | Brian It looks to me as thought the lower surface of the flap is not aligned with the lower surface of the wing...or is it just how it looks in the photo?
Will
William Daniell
LONGPORT
+57 310 295 0744
from?
Brian
Sydney, Aus.
budyerly@msn.com
Posted: Sun Oct 04, 2020 12:01 pm Post subject: Re: W20 Bracket spec |
Brian,
You can never go wrong with 6061-T6 1/8 inch sheet.
The advice given is quite good.
1. Be sure to make the flap fit on the left and right absolutely identical in gap between flap LE and closeout, dead level with the bottom of the wing. Make the line through the inboard and outboard flap eyes even and at the right point using the template. Middle flap bracket is set with string. IF THE FLAP W19 OR 20 IS TOO SHORT: Lay out your template and assure the wing flap is positioned per the manual using the incidence board and dead level with the bottom of the wing then clamp your W19/20 brackets. If too short, simply draw out a new one out of carboard for the outer shape and make another out of 1/8 6061-T6 After fab is complete, clamp in place and check operation. If off laterally due to a FL1 or 2 misalignment , you may either bend the W19/20 or use a spacer to displace the bracket to allow smooth operation.
2. I don't set my flap pins exactly like the manual. I use a compass (actually a 3/4 inch thick stick and pin/pen). Each flap drive pin needs to be set the same. I find that the swing of the flap tube and hinges is slightly off as indicated in the manual and by using a large "compass" I can set each flap pin so it is exactly in line with the hinges. It is not a big deal, but for those of you always having to lift or pull down on a flap to get the flap engaged with the wing pins in alignment, that is your problem or at least part of it.
I've attached a picture for my shop technique on the compass concept.
Best Regards,
Bud Yerly
137.51 KB |
6909 Time(s) |
