Can I power ADS-B from Transponder switched output?
rparigoris
PostPosted: Thu Oct 01, 2020 9:00 am    Post subject: Can I power ADS-B from Transponder switched output? Reply with quote
Hi Group I have a Garmin GDL-82 ADS-B that draws .35A typical and .4A maximum. I have a Becker Mode-C transponder that has a 1A switched output. Is there a good reason why I should not use the transponder switched output to power the ADS-B? I don't have an avionics bus. Ron P.
PostPosted: Thu Oct 01, 2020 9:41 am    Post subject: Re: Can I power ADS-B from Transponder switched output? Reply with quote
Since the two units work together as a team, it is not an emergency if you lose both.
On the other hand, best practice is to protect each individual load with its own fuse.
Joe Gores
rparigoris
PostPosted: Thu Oct 01, 2020 9:48 am    Post subject: Re: Can I power ADS-B from Transponder switched output? Reply with quote
Hi User 9253 The switched output of the Becker transponder has a 1 amp fuse. Is that OK? Ron P.
PostPosted: Thu Oct 01, 2020 12:15 pm    Post subject: Re: Can I power ADS-B from Transponder switched output? Reply with quote
OK then, since the transponder DC output is fused and units are related, I think it is OK to wire them as proposed.
Joe Gores
