Regarding raising the nose wheel - 9/27/2020
Gary.Leinberger(at)miller
PostPosted: Mon Sep 28, 2020 5:40 am    Post subject: Regarding raising the nose wheel - 9/27/2020 Reply with quote
My advice for this is from Bud Yerly - Put chocks under the main gear on both front and rear of the wheels. Use rope and four cinder blocks - two on each side. Take the stabs off. Run the ropes through each two block set - (one block fore and aft of the stab control shaft). The first time you will have to adjust the length of the ropes to get the nose wheel where you want it. The blocks should just hit the ground - it adds to the stability. Put the two sets of cinder blocks on - and it will pick up the nose wheel right where you want (after adjustment of the ropes). Works very well and goes well with my other precision Europa tools (the carpeted bench to lay on when working across the baggage area in the rear, and my wooden stand to hold up the tail when I am working in the rear.
Gary Leinberger
A237 -
Europa High-top Trigear
912S
410 hours
