Fuel Pump
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List
mikepienaar09(at)gmail.co
PostPosted: Sun Sep 13, 2020 11:24 am    Post subject: Fuel Pump Reply with quote
Thanks again for your help, got my engine started and will check oil level in fuel pump again when I have run it again.
I cannot visualise what the oil does in the fuel pump. I have model 5151.03 and the manual mentions oil in through pressure reducing valve (29)
with the level controlled by a drain hole (31) and out to the scavenge pump  (32) You  say "The pump is just sensing oil pressure"
May I ask you to explain again.
If it is not too much trouble is there a convenient time for us to chat on the phone?
Thanks again and keep well
Mike
I apologize if this is a duplicate
- The Matronics Lom-List Email Forum -
http://www.matronics.com/Navigator?Lom-List
sjbeaver(at)gmail.com
PostPosted: Sun Sep 13, 2020 5:03 pm    Post subject: Fuel Pump Reply with quote
The injection system determines how much fuel to deliver by measuring three inputs: Manifold pressure (based on throttle position) atmospheric pressure and oil pressure. Manifold pressure and atmospheric pressure are very much lower than oil pressure, so a pressure reducer is used to get the oil pressure into the same sort of range as the other two.
The purpose of manifold and atmospheric pressure is obvious. The oil pressure is used to provide automatic enrichment for starting. When you are starting the engine, oil pressure is zero so extra fuel is supplied. Once th engine is running, oil pressure comes up and the mixture is automatically leaned to the correct setting. Think of it as a sort of automatic choke. Steve-- Stephen BeaverTel: 614-937 4189
On Sep 13, 2020, at 3:24 PM, mike Pienaar <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
Mike
PostPosted: Sun Sep 13, 2020 6:25 pm    Post subject: Fuel Pump Reply with quote
Thanks Steve
I was considering using a pre-oil system that has a reservoir of pressurized oil that will fill the oil galeries before start..According to the way I read you explanation this will not work and my mixture at start will not be risch enough?
Mike
On Sun, Sep 13, 2020 at 6:03 PM sjbeaver <sjbeaver(at)gmail.com (sjbeaver(at)gmail.com)> wrote:
Steve
Stephen Beaver
Tel:     614-937 4189
Mike
PostPosted: Tue Sep 15, 2020 11:35 am    Post subject: Fuel Pump Reply with quote
I don't think a pre-oiler would be a problem. The only caveat would be that you might need to wait a few seconds after the pre-oiler pump stops before pressing the starter button. You need the oil pressure to be low so that the injection system can do its stuff. Steve-- Stephen BeaverTel: 614-937 4189
On Sep 13, 2020, at 10:25 PM, mike Pienaar <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
Thanks Steve
Mike
Mike
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List All times are GMT - 8 Hours
