after breakdown report
lcottrell
PostPosted: Fri Aug 28, 2020 2:30 pm    Post subject: after breakdown report Reply with quote
Perhaps you might remember my problems after my Aug 2 flight wherein my EIS went crazy. While it for the most part seems to be corrected, I still do not understand fully why it happened. Apparently it was a cascade type of event where the final straw was the disconnection of one of my fuel tanks, capacitance wires.
One of my "smart" friends came for a visit and we began to try to find my problem. My EIS was showing19 volts and all kind of weird readings on all the sensors. While we were trying to figure out what could be the problem, I flicked the switch which reads my fuel sensors. (With that I remember that was the lead up to all my EIS problems. ) Its a double pole double throw switch, so that I can see how much is in each tank. I flicked it to the other side and we momentarily had sanity back again. Tracing the wires found that one of them had came out of the squeeze connector. All in all we found about 3 wires that were loose. The high voltage burned out my little warning light I guess.
I also replaced my voltage regulator, (at) double the cost of last time. as well as replaced the 22000 capacitor. None of which had any effect on the problem. Go figure :-/.    Anyway back in the air in time for our fly in.
Larry
enw7762(at)yahoo.com
PostPosted: Sat Sep 05, 2020 11:39 am    Post subject: after breakdown report Reply with quote
