Memory foam UK
davidjoyce(at)doctors.org
PostPosted: Thu Aug 27, 2020 7:59 am    Post subject: Memory foam UK Reply with quote
I have a largish quantity of 6.5cm thick memory foam , actually 2 lots of 150 x90 cm., which I am happy to give to anyone who cares to collect it. Having a layer of memory foam under and behind you is an effective way of lessening the damage to you in the case of a hard or crash landing. This comes from a NASA designed mattress just replaced by an even more expensive mattress at the instigation of she who sleeps on the other side of it! My cushions were made from 2.5 cm sheets of memory foam, which then came in three colours corresponding to three degrees of softness. This mattress foam I think corresponds to somewhere between the medium and softest versions, and would make good extra cushions to be available for small passengers
Regards, David Joyce.
europaul383(at)gmail.com
PostPosted: Fri Aug 28, 2020 12:13 am    Post subject: Memory foam UK Reply with quote
Hello David,
Happy to relieve you of some or all of that, thanks! I don't think I need all of it, but I'll measure and revert. Collection at Kemble, or chez Joyce?
All the best,
Paul
-------- Original message --------
Date: 27/08/2020 17:04 (GMT+00:00)
To: europa list <europa-list(at)matronics.com>
Subject: Europa-List: Memory foam UK
