Anti corrosion on connections?
rparigoris
PostPosted: Wed Aug 26, 2020 6:38 pm    Post subject: Anti corrosion on connections? Reply with quote
Hi Group, thank you for answer on using starter for ground on my Rotax 914. The answer is yes I can put an An-4 nut on the other side of bolt.
Question: Should I use any anti corrosion goop on my starter ground joint? Something like Al-Ox which is a green goop you use when "tipping" aluminium home wires with copper in wire nut? Or??
Next question is for Ring terminals, PIDG Fast-Ons and D-Sub connectors, should any goop be applied to these connections? CRC 2-56? Or? Thx. Ron P
PostPosted: Wed Aug 26, 2020 7:07 pm    Post subject: Anti corrosion on connections? Reply with quote
At 09:38 PM 8/26/2020, you wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com>
Nope. A properly torqued fastener provides
a gas-tight connection where it matters. The
visible surfaces may get pretty ugly with age
but INSIDE, it will be just as bright and clean
as it was when you made up the joint 10 years ago.
Only as local extremes suggest . . . like tropical
sea shores or ocean based seaplanes. Then
consult your local mechanics for their favorite
potions demonstrated to forestall . . . not halt but
forestall environmental destruction of the
airplane.
But for the vast majority of our favorite
pleasure machines no special treatments are
necessary or useful.
