Use 1/4" hole on starter for engine ground?(PS)
PostPosted: Wed Aug 26, 2020 2:16 pm    Post subject: Use 1/4" hole on starter for engine ground?(PS) Reply with quote
Torque it up until you're worried for the
future of your 1/4" ratchet and call it
good.
P.S. as a point of reference, the terminals on
a PC680 battery are 6 mm female threads in brass . . .
[img]cid:7.1.0.9.0.20200826165010.02c22560(at)aeroelectric.com.0[/img]
Your primary concern at this junction
is integrity under engine vibration and
temperature variations. Your hardware
will be steel and torqued to a lot
higher forces/pressures than the battery . . .
 Filesize:  11.88 KB
 Viewed:  1354 Time(s)
