inexpensive (or possibly just cheap) solder sleeves
ceengland7(at)gmail.com
PostPosted: Thu Aug 20, 2020 2:25 pm    Post subject: inexpensive (or possibly just cheap) solder sleeves Reply with quote
Solder sleeves are cool tools, but I'm way too cheap to pay almost a dollar a joint. So, I've always just soldered & then heat shrunk to insulate.
But, while prowling an Asian shopping site, I stumbled upon these:
https://www.tomtop.com/p-e12176.html?rc_token=null
I'm sorely tempted to roll $20 worth if dice to see if they're any good.
Charlie
PostPosted: Thu Aug 20, 2020 3:33 pm    Post subject: Re: inexpensive (or possibly just cheap) solder sleeves Reply with quote
Don't do it Charlie. I do NOT think that they are solder sleeves. I get the
impression that they are crimp connectors. Nowhere does it mention solder.
Heat is used to shrink the tubing.
Joe Gores
rv8iator
PostPosted: Thu Aug 20, 2020 5:30 pm    Post subject: inexpensive (or possibly just cheap) solder sleeves Reply with quote
Charlie...et al.
I purchased a similar looking box from Amazon and was disappointed.  The shrink sleeves are extremely thin .008-.012 in wall.  the solder sleeves were also very thin wall.  If using multi strand with fine strands there is insufficient solder to fully wet out the strands.
Chris
On Thu, Aug 20, 2020 at 3:34 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
C. Stone (RV8iator)
