ceengland7(at)gmail.com Guest
Posted: Thu Aug 13, 2020 12:09 pm Post subject: ACK E-01 ELT SDR (warning: Rant mode ON) |
During my Condition Inspection of my (purchased) RV-6, I prepared to check the ELT batteries for date/operation. The builder had mounted the ELT behind the passenger seat in the baggage compartment, with the antenna directly above just inside the back glass. Not ideal for packing luggage, but certainly easy access for service (I thought).
I leaned over the seats and flipped open the two latches, and picked up the ELT to disconnect the coax & 'phone wire' that runs to the panel mounted control. No issue with the coax. But the phone wire is *hard wired* into the top of the ELT by the mfgr. To compound matters, the builder, in his infinite wisdom, drilled a hole in the baggage floor & snaked the cable through corrugated tubing that disappears into the inaccessible space under the baggage compartment. So now the 'portable' ELT, complete with its attached portable whip, is portable to a distance of about 2" above the floor of the baggage compartment.
I get it that not all builders have good sense, and all of us have 'bad decision days', but how could a mfgr do something this stupid, and I know it's pointless to ask, but how could the FAA be so stupid as to certify the thing?
Yes, I realize that the builder could have left a 2-foot service loop hanging out with the splice in the baggage compartment, but IT'S AN E(mergency)LT. In an actual emergency, finding a latch on the case would be a lot simpler and quicker than finding the splice point in the cable.
Does filing a Service Difficulty Report on a 20 year old product make any sense?
OK, rant mode off; back to your regularly scheduled programming.Â
halbenjamin101(at)gmail.c Guest
Posted: Thu Aug 13, 2020 2:53 pm Post subject: ACK E-01 ELT SDR (warning: Rant mode ON) |
Hi Charlie,
Sounds like it’s time to cut the cord, buy a couple of crimp on phone connectors and be done with it. I too find things that could have been done differently to make maintenance easier, but then again again I built it.
Hal Benjamin
RV4, Flying
| Quote: | On Aug 13, 2020, at 4:20 PM, Charlie England <ceengland7(at)gmail.com> wrote:
Posted: Thu Aug 13, 2020 3:36 pm Post subject: ACK E-01 ELT SDR (warning: Rant mode ON) |
I hear you, but there is zero slack. I was able to pivot it out of its holder, and rotate it enough to get to all 4 of the battery screws, but I seriously doubt that I'd have enough left on each end of the cut to strip & crimp both ends.
As the subject line says, this is more of a rant than a call for help. I'm impressed almost daily by 'aircraft quality'.
The next time I need to pull up the seat pans, I'll pull some slack down from the panel and back to ELT location.
On 8/13/2020 5:48 PM, Hal Benjamin wrote:
| Quote: | Hi Charlie,
Sounds like it’s time to cut the cord, buy a couple of crimp on phone connectors and be done with it. I too find things that could have been done differently to make maintenance easier, but then again again I built it.Â
Hal BenjaminÂ
RV4, FlyingÂ
| Quote: | On Aug 13, 2020, at 4:20 PM, Charlie England <ceengland7(at)gmail.com> (ceengland7(at)gmail.com) wrote:
Posted: Sat Aug 15, 2020 6:15 pm Post subject: ACK E-01 ELT SDR (warning: Rant mode ON) |
I mounted the my ACK unit behind the baggage bulkhead along with the antenna. Didn't really consider the portable aspect. There is a generous service loop in the phone wire (which I think was more than long enough to reach the panel for the remote piece.
Bill "just sharing since I'm not flying today" Watson
On 8/13/2020 4:05 PM, Charlie England wrote:
| Quote: | During my Condition Inspection of my (purchased) RV-6, I prepared to check the ELT batteries for date/operation. The builder had mounted the ELT behind the passenger seat in the baggage compartment, with the antenna directly above just inside the back glass. Not ideal for packing luggage, but certainly easy access for service (I thought).
Posted: Sat Aug 15, 2020 7:57 pm Post subject: ACK E-01 ELT SDR (warning: Rant mode ON) |
Yes, and that service loop got permanently installed, through a conduit in the nonremoveable floor of the baggage compartment. The generous service loop should have been a removable cable.
Sent from BlueMail
On Aug 15, 2020, at 9:22 PM, Bill Watson <mauledriver(at)nc.rr.com (mauledriver(at)nc.rr.com)> wrote: | Quote: | I mounted the my ACK unit behind the baggage bulkhead along with the antenna. Didn't really consider the portable aspect. There is a generous service loop in the phone wire (which I think was more than long enough to reach the panel for the remote piece.
